extern const unsigned char partition_table_bin_start[] asm("_binary_partition_table_bin_start");
extern const unsigned char partition_table_bin_end[] asm("_binary_partition_table_bin_end");
static const char *PARTITION_TABLE_UPDATE_TAG = "PartitionTableUpdate";
#define PARTITION_TABLE_SECTOR_SIZE 0x1000
#define EXPECTED_PARTITION_TABLE_SIZE (partition_table_bin_end - partition_table_bin_start)
void PartitionTablePerformUpdate(void)
ESP_LOGI(PARTITION_TABLE_UPDATE_TAG, "Updating partition table");
unsigned char* pBuffer = (unsigned char*)heap_caps_calloc(EXPECTED_PARTITION_TABLE_SIZE, sizeof(unsigned char), MALLOC_CAP_8BIT);
assert(pBuffer);
esp_err_t flashOperationStatus = ESP_OK;
do
if ((flashOperationStatus = esp_flash_erase_region(esp_flash_default_chip, CONFIG_PARTITION_TABLE_OFFSET, PARTITION_TABLE_SECTOR_SIZE)) != ESP_OK)
ESP_LOGE(PARTITION_TABLE_UPDATE_TAG, "esp_flash_erase_region failed with code %d", flashOperationStatus);
else if ((flashOperationStatus = esp_flash_write_encrypted(esp_flash_default_chip, CONFIG_PARTITION_TABLE_OFFSET, partition_table_bin_start, EXPECTED_PARTITION_TABLE_SIZE)) != ESP_OK)
ESP_LOGE(PARTITION_TABLE_UPDATE_TAG, "esp_flash_write_encrypted failed with code %d", flashOperationStatus);
else if ((flashOperationStatus = esp_flash_read_encrypted(esp_flash_default_chip, CONFIG_PARTITION_TABLE_OFFSET, pBuffer, EXPECTED_PARTITION_TABLE_SIZE)) != ESP_OK)
ESP_LOGE(PARTITION_TABLE_UPDATE_TAG, "esp_flash_read_encrypted failed with code %d", flashOperationStatus);
} while (memcmp(pBuffer, partition_table_bin_start, EXPECTED_PARTITION_TABLE_SIZE) != 0);
heap_caps_free(pBuffer);
ESP_LOGI(PARTITION_TABLE_UPDATE_TAG, "Partition table successfully updated");
ESP_LOGW(PARTITION_TABLE_UPDATE_TAG, "If you have not done so already, power cycle the device once to apply the new partition table");
std::this_thread::sleep_for(std::chrono::seconds(5));
ESP_LOGI(PARTITION_TABLE_UPDATE_TAG, "After a power cycle, proceed with the USB firmware update");
SPIWP:0xee
mode:DIO, clock div:1
load:0x3ffe6270,len:0x32e4
load:0x4004c000,len:0xc34
load:0x40050000,len:0x4f58
entry 0x4004c200
I (39) boot: ESP-IDF v5.0.7 2nd stage bootloader
I (39) boot: compile time 12:36:41
D (39) bootloader_flash: non-XMC chip detected by SFDP Read (00), skip.
D (42) bootloader_flash: mmu set block paddr=0x00000000 (was 0xffffffff)
I (48) boot: chip revision: v1.0
D (51) boot.esp32s2: magic e9
D (54) boot.esp32s2: segments 03
D (57) boot.esp32s2: spi_mode 02
D (60) boot.esp32s2: spi_speed 0f
D (63) boot.esp32s2: spi_size 02
I (66) boot.esp32s2: SPI Speed : 80MHz
I (70) boot.esp32s2: SPI Mode : DIO
I (74) boot.esp32s2: SPI Flash Size : 4MB
D (77) boot: Enabling RTCWDT(9000 ms)
I (81) boot: Enabling RNG early entropy source...
D (85) bootloader_flash: rodata starts from paddr=0x0000e000, size=0xc00, will be mapped to vaddr=0x3f000000
V (95) bootloader_flash: after mapping, starting from paddr=0x00000000 and vaddr=0x3f000000, 0x10000 bytes are mapped
D (105) boot: mapped partition table 0xe000 at 0x3f00e000
D (110) flash_parts: partition table verified, 7 entries
I (115) boot: Partition Table:
I (118) boot: ## Label Usage Type ST Offset Length
D (124) boot: load partition table entry 0x3f00e000
D (129) boot: type=1 subtype=2
I (132) boot: 0 nvs WiFi data 01 02 0000f000 00004000
D (138) boot: load partition table entry 0x3f00e020
D (143) boot: type=1 subtype=0
I (146) boot: 1 otadata OTA data 01 00 00013000 00002000
D (152) boot: load partition table entry 0x3f00e040
D (157) boot: type=1 subtype=1
I (160) boot: 2 phy_init RF data 01 01 00015000 00001000
D (166) boot: load partition table entry 0x3f00e060
D (171) boot: type=0 subtype=10
I (174) boot: 3 ota_0 OTA app 00 10 00020000 00170000
D (180) boot: load partition table entry 0x3f00e080
D (185) boot: type=0 subtype=11
I (188) boot: 4 ota_1 OTA app 00 11 00190000 00170000
D (194) boot: load partition table entry 0x3f00e0a0
D (199) boot: type=1 subtype=4
I (202) boot: 5 nvs_key NVS keys 01 04 00300000 00001000
I (208) boot: End of partition table
D (212) boot: OTA data offset 0x13000
D (215) bootloader_flash: rodata starts from paddr=0x00013000, size=0x2000, will be mapped to vaddr=0x3f000000
V (225) bootloader_flash: after mapping, starting from paddr=0x00010000 and vaddr=0x3f000000, 0x10000 bytes are mapped
D (235) boot: otadata[0]: sequence values 0x00000001
D (240) boot: otadata[1]: sequence values 0xffffffff
D (245) boot_comm: Only otadata[0] is valid
D (248) boot: Active otadata[0]
D (251) boot: Mapping seq 0 -> OTA slot 0
D (255) boot: Trying partition index 0 offs 0x20000 size 0x170000
D (261) esp_image: reading image header @ 0x20000
D (265) bootloader_flash: mmu set block paddr=0x00020000 (was 0xffffffff)
D (272) esp_image: image header: 0xe9 0x06 0x02 0x02 400230a4
V (277) esp_image: loading segment header 0 at offset 0x20018
V (283) esp_image: segment data length 0x6145c data starts 0x20020
V (289) esp_image: segment 0 map_segment 1 segment_data_offs 0x20020 load_addr 0x3f000020
I (297) esp_image: segment 0: paddr=00020020 vaddr=3f000020 size=6145ch (398428) map
D (304) esp_image: free data page_count 0x00000037
D (309) bootloader_flash: rodata starts from paddr=0x00020020, size=0x6145c, will be mapped to vaddr=0x3f000000
V (318) bootloader_flash: after mapping, starting from paddr=0x00020000 and vaddr=0x3f000000, 0x70000 bytes are mapped
V (415) esp_image: loading segment header 1 at offset 0x8147c
D (415) bootloader_flash: mmu set block paddr=0x00080000 (was 0xffffffff)
V (416) esp_image: segment data length 0x317c data starts 0x81484
V (422) esp_image: segment 1 map_segment 0 segment_data_offs 0x81484 load_addr 0x3ffc5a20
I (430) esp_image: segment 1: paddr=00081484 vaddr=3ffc5a20 size=0317ch ( 12668) load
D (437) esp_image: free data page_count 0x00000037
D (442) bootloader_flash: rodata starts from paddr=0x00081484, size=0x317c, will be mapped to vaddr=0x3f000000
V (451) bootloader_flash: after mapping, starting from paddr=0x00080000 and vaddr=0x3f000000, 0x10000 bytes are mapped
V (465) esp_image: loading segment header 2 at offset 0x84600
D (467) bootloader_flash: mmu set block paddr=0x00080000 (was 0xffffffff)
V (474) esp_image: segment data length 0xba10 data starts 0x84608
V (480) esp_image: segment 2 map_segment 0 segment_data_offs 0x84608 load_addr 0x40022000
0x40022000: _WindowOverflow4 at /Users/mukukakapembwa/esp/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/xtensa_vectors.S:1747
I (488) esp_image: segment 2: paddr=00084608 vaddr=40022000 size=0ba10h ( 47632) load
D (495) esp_image: free data page_count 0x00000037
D (500) bootloader_flash: rodata starts from paddr=0x00084608, size=0xba10, will be mapped to vaddr=0x3f000000
V (509) bootloader_flash: after mapping, starting from paddr=0x00080000 and vaddr=0x3f000000, 0x20000 bytes are mapped
V (533) esp_image: loading segment header 3 at offset 0x90018
D (533) bootloader_flash: mmu set block paddr=0x00090000 (was 0xffffffff)
V (534) esp_image: segment data length 0xe6d4c data starts 0x90020
V (540) esp_image: segment 3 map_segment 1 segment_data_offs 0x90020 load_addr 0x40080020
0x40080020: _stext at ??:?
I (548) esp_image: segment 3: paddr=00090020 vaddr=40080020 size=e6d4ch (945484) map
D (555) esp_image: free data page_count 0x00000037
D (560) bootloader_flash: rodata starts from paddr=0x00090020, size=0xe6d4c, will be mapped to vaddr=0x3f000000
V (570) bootloader_flash: after mapping, starting from paddr=0x00090000 and vaddr=0x3f000000, 0xf0000 bytes are mapped
V (785) esp_image: loading segment header 4 at offset 0x176d6c
D (785) bootloader_flash: mmu set block paddr=0x00170000 (was 0xffffffff)
V (785) esp_image: segment data length 0x8010 data starts 0x176d74
V (791) esp_image: segment 4 map_segment 0 segment_data_offs 0x176d74 load_addr 0x4002da10
0x4002da10: spi_ll_infifo_full_clr at /Users/mukukakapembwa/esp/esp-idf/components/hal/esp32s2/include/hal/spi_ll.h:265
(inlined by) spi_slave_hal_prepare_data at /Users/mukukakapembwa/esp/esp-idf/components/hal/spi_slave_hal_iram.c:45
I (799) esp_image: segment 4: paddr=00176d74 vaddr=4002da10 size=08010h ( 32784) load
D (807) esp_image: free data page_count 0x00000037
D (811) bootloader_flash: rodata starts from paddr=0x00176d74, size=0x8010, will be mapped to vaddr=0x3f000000
V (821) bootloader_flash: after mapping, starting from paddr=0x00170000 and vaddr=0x3f000000, 0x10000 bytes are mapped
V (840) esp_image: loading segment header 5 at offset 0x17ed84
D (840) bootloader_flash: mmu set block paddr=0x00170000 (was 0xffffffff)
V (844) esp_image: segment data length 0x1244 data starts 0x17ed8c
V (849) esp_image: segment 5 map_segment 0 segment_data_offs 0x17ed8c load_addr 0x0
I (857) esp_image: segment 5: paddr=0017ed8c vaddr=00000000 size=01244h ( 4676)
D (864) esp_image: free data page_count 0x00000037
D (869) bootloader_flash: rodata starts from paddr=0x0017ed8c, size=0x1244, will be mapped to vaddr=0x3f000000
V (878) bootloader_flash: after mapping, starting from paddr=0x00170000 and vaddr=0x3f000000, 0x10000 bytes are mapped
V (890) esp_image: image start 0x00020000 end of last section 0x0017ffd0
D (895) bootloader_flash: mmu set block paddr=0x00170000 (was 0xffffffff)
D (902) boot: Calculated hash: 961acd69e1a08be2d48f2fad1e5fa25a787e057f1217861328f4395e7332a4e6
I (920) boot: Loaded app from partition at offset 0x20000
I (920) boot: Checking flash encryption...
D (920) efuse: In EFUSE_BLK0__DATA2_REG is used 3 bits starting with 18 bit
D (926) efuse: In EFUSE_BLK0__DATA0_REG is used 1 bits starting with 4 bit
V (932) flash_encrypt: CRYPT_CNT 1, write protection 0
I (937) flash_encrypt: flash encryption is enabled (1 plaintext flashes left)
I (944) boot: Disabling RNG early entropy source...
D (949) boot: Mapping segment 0 as DROM
D (952) boot: Mapping segment 3 as IROM
D (956) boot: calling set_cache_and_start_app
D (960) boot: configure drom and irom and start
V (964) boot: rodata starts from paddr=0x00020020, vaddr=0x3f000020, size=0x6145c
V (971) boot: after mapping rodata, starting from paddr=0x00020000 and vaddr=0x3f000000, 0x70000 bytes are mapped
V (981) boot: text starts from paddr=0x00090020, vaddr=0x40080020, size=0xe6d4c
V (988) boot: after mapping text, starting from paddr=0x00090000 and vaddr=0x40080000, 0xf0000 bytes are mapped
D (998) boot: start: 0x400230a4
0x400230a4: call_start_cpu0 at /Users/mukukakapembwa/esp/esp-idf/components/esp_system/port/cpu_start.c:285
W (1021) flash_encrypt: Flash encryption mode is DEVELOPMENT (not secure)
Compile DATE Apr 14 2025 and TIME 12:36:41
abort() was called at PC 0x400259b1 on core 0
0x400259b1: esp_flash_erase_region at /Users/mukukakapembwa/esp/esp-idf/components/spi_flash/esp_flash_api.c:547 (discriminator 5)
Backtrace: 0x400236ae:0x3ffd24c0 0x40029fe5:0x3ffd24e0 0x40030425:0x3ffd2500 0x400259b1:0x3ffd2570 0x4008a0e4:0x3ffd25c0 0x4009b031:0x3ffd25f0 0x40166698:0x3ffd3070
0x400236ae: panic_abort at /Users/mukukakapembwa/esp/esp-idf/components/esp_system/panic.c:425
0x40029fe5: esp_system_abort at /Users/mukukakapembwa/esp/esp-idf/components/esp_system/esp_system.c:153
0x40030425: abort at /Users/mukukakapembwa/esp/esp-idf/components/newlib/abort.c:38
0x4008a0e4: PartitionTablePerformUpdate() at /Users/mukukakapembwa/GC_Projects/ESP32-wifi-driver/src/wifi-module/main/main.cpp:204
0x4009b031: app_main at /Users/mukukakapembwa/GC_Projects/ESP32-wifi-driver/src/wifi-module/main/main.cpp:234
0x40166698: main_task at /Users/mukukakapembwa/esp/esp-idf/components/freertos/app_startup.c:208
ELF file SHA256: 8e6541ea25e6bd48
Rebooting...
ESP-ROM:esp32s2-rc4-20191025
Build:Oct 25 2019
rst:0x3 (RTC_SW_SYS_RST),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x40023293
0x40023293: esp_restart_noos_dig at /Users/mukukakapembwa/esp/esp-idf/components/esp_system/esp_system.c:64 (discriminator 1)
