Hello
I'm designing a custom PCB using an ESP32 that communicates over I²C with multiple devices (SEN55 air quality sensor and 4 ADS1115 ADCs) Currently all devices are connected to the same SDA and SCL lines.
Each device datasheet suggests pull-up resistors on SDA and SCL (SEN55 recommends 4.7kΩ, ADS1115 recommends 10kΩ), and as a result, I currently have 4 resistors on the I²C bus (2 × 4.7kΩ, 2 × 10kΩ).
My questions are:
1. Is it electrically safe and recommended to have multiple pull-up resistor pairs on the same I²C bus?
2. Should I remove all but one pair of pull-ups? If so, which value is ideal for ESP32 with short trace lengths (less than 10 cm)?
Thanks in advance for your help
I²C Pull-up Resistors with Multiple Devices on SDA/SCL – ESP32 Design Question
muhammed12
Re: I²C Pull-up Resistors with Multiple Devices on SDA/SCL – ESP32 Design Question
you will be just fine with just one set of 4.7k on the bus.
The whole concept of the I2C bus is that you have one (1) set of pull up resistors. With every resistor you add in parallel, the pull-up resistors values decreases (if they're the same value, the values become half of it). Normally each device type has a maximum bus drive strength which translates into a minimum pull-up resistor value. Most devices can drive 2k2 though, some even 1k. 4k7 is a very safe default (which I always use), you only need to explore lower values if your bus becomes long, very long, e.g. over 5 meters. Over around 10 meters I'd use a bus extender. Or place another microcontroller altogether.
