[ESP-IDF 5.4.1] HTTPS download errors + esp_tls_conn_read error
matheusQuadros
Postby matheusQuadros » Fri May 16, 2025 2:04 pm
After migrating from ESP-IDF 4.3.4 to 5.4.1, my HTTPS download using esp_http_client became extremely slow, and I’m now getting this error:
E (...) transport_base: esp_tls_conn_read error, errno=No more processes
On 4.3.4, the same file (around 1.5 MB) downloaded in ~3 minutes. Now it takes way more time and most times I can’t finish the download at all due to the error above.
I'm using PSRAM and HTTP_TRANSPORT_OVER_SSL. Free heap seems fine, and I already tried increasing buffer sizes.
Has anything changed in esp_http_client or TLS behavior in 5.4.1 that could cause this?
This is the http config I'm using:
HTTP_generic_event_t xEvent = {0};
    esp_http_client_config_t xConfig = {0};
    xConfig.url = fileDataInfo->url;
    xConfig.is_async = false;
    xConfig.event_handler = HttpApp_xEventHandler;
    xConfig.user_data = &xEvent;
    xConfig.cert_pem = Http_pcCertificate();
    xConfig.transport_type = HTTP_TRANSPORT_OVER_SSL;
    xConfig.timeout_ms = HTTP_CONN_TIMEOUT;
    xConfig.buffer_size = 1024;
    xConfig.buffer_size_tx = 1024;
    esp_http_client_handle_t xClient = esp_http_client_init(&xConfig);
    err = esp_http_client_perform(xClient);
Thanks in advance!
Dimitri_USDI
Re: [ESP-IDF 5.4.1] HTTPS download errors + esp_tls_conn_read error
Postby Dimitri_USDI » Tue May 27, 2025 6:17 pm
We confirm the same behavior on 5.4.1 esp_http_client.
For our use case, we have a cell modem connected via PPPoS and registered as a netif interface.
E (381996) transport_base: esp_tls_conn_read error, errno=No more processes
W (381996) HTTP_CLIENT: esp_transport_read returned:0 and errno:11
Proper handling of EAGAIN and adjusting socket timeout does not seem to resolve the issue.
matheusQuadros
Postby matheusQuadros » Thu May 29, 2025 10:23 am
After a lot of investigation, I found that the issue was caused by setting Wi-Fi power save to maximum:
esp_wifi_set_ps(WIFI_PS_MAX_MODEM)
Changing it to the configuration below seems to have solved the problem:
esp_wifi_set_ps(WIFI_PS_NONE)
Now, in our case, the download works correctly using both Wi-Fi and a cellular modem.
Users browsing this forum: Bytespider, Qwantbot and 4 guests
