Hello everyone,
I am working with an ESP32-C5-DEVKITC-1 v1.1, which has a chip revision of v0.1. My development environment is ESP-IDF v5.5 within Visual Studio Code, using the official Espressif extension.
When I try to flash any application (even a simple hello_world), I consistently encounter the following fatal error:
A fatal error occurred: bootloader/bootloader.bin requires chip revision in range [v1.0 - v1.99] (this chip is revision v0.1). Use --force to flash anyway.
I understand the error is due to a chip revision mismatch. I attempted to solve this by changing the minimum supported chip revision in the configuration editor (both the terminal idf.py menuconfig and the VS Code GUI/Wizard).
However, in both interfaces, the option Component config -> ESP System Settings -> Minimum supported ESP chip revision is grayed out and locked. I am unable to change it from the default value, which seems to be for revision v1.0 and higher.
Is this an intentional restriction in IDF v5.5 to block pre-release silicon? Is there a recommended workaround or a way to override this configuration lock to allow flashing on this v0.1 chip?
Any help would be greatly appreciated.
Thank you.
Environment Summary:
Hardware: ESP32-C5-DEVKITC-1 v1.1 (Chip Rev v0.1)
ESP-IDF Version: v5.5
Operating System: [Windows 10]
IDE: Visual Studio Code with ESP-IDF Extension
ESP32-C5 Rev 0.1 Flashing Error: bootloader requires chip revision in range [v1.0 - v1.99]
Users browsing this forum: Applebot, Baidu [Spider], PetalBot and 3 guests
