I2C BUS Error
balabhaskar.vg
I2C BUS Error
Hi Sir
In my project I am using ESP32-S3-MINI-1U-N8 as the main controller unit, It has 4 slaves in its I2C
1)EEPROM
2) Fuel Gauge
3)MPPT Charger
4) GPIO Expander
The LT8491 is battery charger IC whose input is from solar panel. When I probe the I2C SCL line of the MPPT charger LT8491 we found out that the I2C bus line its coming down from 3.3V to 2.2V when it is in IDLE condition that is not powered from solar panel and in the IC's datasheet its has been specified that the Master (ESP-32-S3-MINI-N8) has to support Clock Stretching for effective communication. Is there any way to enable this feature in ESP32S3miniN8. Also could you explain the attached image section specified in the technical manual and suggest a solution for this.
1)EEPROM
2) Fuel Gauge
3)MPPT Charger
4) GPIO Expander
- Technical Reference manual
- I2C Clock stretching.png (183.48 KiB) Viewed 1158 times
Re: I2C BUS Error
Sounds like the LT8491 is only using the solar panel as the power source, and effectively takes down the I2C bus when that doesn't provide enough power (probably because of internal ESD diodes conducting the I2C lines to a sagging power rails). Are you sure that chips EXTVCC is connected to something (e.g. the battery) that delivers more than 6.25V?The LT8491 is battery charger IC whose input is from solar panel. When I probe the I2C SCL line of the MPPT charger LT8491 we found out that the I2C bus line its coming down from 3.3V to 2.2V when it is in IDLE condition that is not powered from solar panel
The ESP32S3 supports clock stretching out of the box, no need to enable it.and in the IC's datasheet its has been specified that the Master (ESP-32-S3-MINI-N8) has to support Clock Stretching for effective communication. Is there any way to enable this feature in ESP32S3miniN8.
That applies to I2C slave mode and not to your situation as you're using the ESP32 as an I2C master.Also could you explain the attached image section specified in the technical manual and suggest a solution for this.
balabhaskar.vg
Re: I2C BUS Error
Thanks, Sprite,
For your support,
Is there any way we can enable clock stretching in the master mode.
With regards
Balabhaskar V G
For your support,
Yes LT8491 is only powered from solar panel, we have tried that but could not get it to work."Sounds like the LT8491 is only using the solar panel as the power source, and effectively takes down the I2C bus when that doesn't provide enough power (probably because of internal ESD diodes conducting the I2C lines to a sagging power rails). Are you sure that chips EXTVCC is connected to something (e.g. the battery) that delivers more than 6.25V?"
Could you please explain this ?The ESP32S3 supports clock stretching out of the box, no need to enable it.
With regards
Balabhaskar V G
Re: I2C BUS Error
The ESP32S3 always has support for clock stretching enabled.Could you please explain this ?The ESP32S3 supports clock stretching out of the box, no need to enable it.
Then that is your problem. The LT8491 is getting starved for power, and tries to draw current from your I2C lines to stay alive; unsurprisingly, an I2C bus doesn't really like chips using it as a power supply so the entire bus collapses. You need to make sure your LT8491 stays powered; that is the core of your problem.Yes LT8491 is only powered from solar panel, we have tried that but could not get it to work."Sounds like the LT8491 is only using the solar panel as the power source, and effectively takes down the I2C bus when that doesn't provide enough power (probably because of internal ESD diodes conducting the I2C lines to a sagging power rails). Are you sure that chips EXTVCC is connected to something (e.g. the battery) that delivers more than 6.25V?"
balabhaskar.vg
Re: I2C BUS Error
Hi Sir,
Is it applicable for ESP32S3 acting as master also.The ESP32S3 always has support for clock stretching enabled.
Thank you sir for your suggestion I will check with the team.Then that is your problem. The LT8491 is getting starved for power, and tries to draw current from your I2C lines to stay alive; unsurprisingly, an I2C bus doesn't really like chips using it as a power supply so the entire bus collapses. You need to make sure your LT8491 stays powered; that is the core of your problem.
balabhaskar.vg
Re: I2C BUS Error
Hi Sprite,
We have observed that the previously mentioned I²C bus issue also occurs when the MPPT charger (LT8491) is powered and it is continuously occurring but rather randomly . Could you please confirm whether the ESP32, when operating as the master, supports I²C clock stretching?
Thanks and regards,
Balabhaskar V G
Thanks and regards,
Balabhaskar V G
Re: I2C BUS Error
Interesting. Although I2C is not designed for hotplugging, it is possible to have slave attached that don't receiver power. These slaves will just "NAK" everything, just like they weren't there anyway.
For this to work, you need to have the pull up resistors always powered (e.g. by the ESP32). You also need to make sure your device doesn't try to take it's power supply from the SCL and SDA lines. IC's often have input pin protection diodes, one from the pin to Vcc and one from Vss to the pin. This protection diode will make the IC draw current from the SCL and SDA lines. If your IC has them, you will need to work this around. One way that comes to mind is to use a MOSFET in both SCL and SDA lines, controlled by the power supply of your troublesome IC. If it's power goes away, it will also isolate the IC from the bus. AFAIK there are also IC's that can isolate I2C buses, may they're more robust. A common I2C bus multiplexer won't help here I fear.
Re: I2C BUS Error
balabhaskar.vg
Re: I2C BUS Error
Thank you for suggestion,
We will consider it and let you know further updates.
Alternatively , does ESP32-S3 mini supports clock stretching, when it is acting as master ?
Users browsing this forum: Google [Bot] and 4 guests
