Hello everyone!
I know FreeRTOS supports TLS. However it is not clear if I can use "__thread" type modifier to make my global variables to be thread-specific? Or should I use API provided by FreeRTOS and manage my global variables myself?
What I am trying to do: I am converting some application to ESP-IDF. Application uses global variables, so I want to make these variables to be "per thread" variables
Thank you!
Is __thread type modifier supported by ESP-IDF's toolchain?
Re: Is __thread type modifier supported by ESP-IDF's toolchain?
Oh, I should be making a test by myself, before asking.
Anyway.
Yes, __thread type specifier works as it should.
PS:
No, started to celebrate too early.
When I added third variable with __thread (other two was pointer and unsigned int) the ESP32 goes into infinite reboot with StoreProhibited exception. The problems is that I don't even use this variable.
It is defined as
The exception decoded to absolute nonsence:
It is nonsence, because my application does not use class HardwareSerial, it is a pure C code which uses printf()
As soon as I remove __thread specifier, or variable definition completely - it works.
Any ideas?
__thread is buggy?
@ESP_igrr , @Sprite
Anyway.
PS:
It is defined as
static __thread const char *prompt = "prompt";
Decoding stack results
0x4200e20b: HardwareSerial::_uartEventTask(void*) at C:\Users\WINDOWS\AppData\Local\Arduino15\packages\esp32\hardware\esp32\3.3.0\cores\esp32\HardwareSerial.cpp:268
0x42018dce: spi_flash_hal_init at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/hal\spi_flash_hal.c:143
0x40376556: call_start_cpu0 at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/xtensa/include\xt_utils.h:41
Any ideas?
__thread is buggy?
@ESP_igrr , @Sprite
Thanks!
Slava.
Slava.
Oh ok, I investigated the issue and found something interesting:
If you have __thread (_Thread_local) variable, which you try to assign (or read) in a function with "constructor" attribute
whole thing will crash:
My guess that it happens because .ctor section is processed before any task is created. Is this specific to xtensa toolchain or it is normal behaviour?
static __thread void *sample;
void __attribute__((constructor)) __init_sample() {
sample = NULL;
}Thanks!
Slava.
Slava.
Users browsing this forum: Google [Bot] and 3 guests
