I am creating a game board using a S3-WROOM. When a player places a piece on the board the ESP should detect it and begin sending it some PWM to drive a couple of LEDs. Is this a reasonable circuit or do I need the reed switch on a separate net? TIA
Reed switch for presence detection
Re: Reed switch for presence detection
Should work, but A. keep in mind the max current through the reed switch you're using, and B. you may need a pulldown on the switched 5V as well as the LEDs might not pull the 5V line down by themselves. Also note that technically the ESP32 GPIOs aren't 5V compatible, although I doubt it'll pose an issue in your case; you could change R1 for a divider network that makes it into 3V3 if you're worried about that.I am creating a game board using a S3-WROOM. When a player places a piece on the board the ESP should detect it and begin sending it some PWM to drive a couple of LEDs. Is this a reasonable circuit or do I need the reed switch on a separate net? TIA
Occam Blazer
Thanks for the sanity check. The reed switch I have is 1A which might be undersized for 60 leds even though they'll be on about 25% duty. I'll source a more appropriate switch when I start real testing.Should work, but A. keep in mind the max current through the reed switch you're using, and B. you may need a pulldown on the switched 5V as well as the LEDs might not pull the 5V line down by themselves. Also note that technically the ESP32 GPIOs aren't 5V compatible, although I doubt it'll pose an issue in your case; you could change R1 for a divider network that makes it into 3V3 if you're worried about that.I am creating a game board using a S3-WROOM. When a player places a piece on the board the ESP should detect it and begin sending it some PWM to drive a couple of LEDs. Is this a reasonable circuit or do I need the reed switch on a separate net? TIA
And good catch with the gpio voltage.
MicroController
Check what the LEDs' DIN pin does when the LED has no power. May be that it puts a load on the DIN signal effectively pulling it low or to some intermediate voltage level.
Users browsing this forum: Perplexity-User and 4 guests
