Issue with MQTT SSL AT Command Response on ESP8684H2 Firmware
Shivam_Kachhatiya
Postby Shivam_Kachhatiya » Mon Sep 01, 2025 6:44 am
I am using the ESP8684H2 AT Command firmware for my application. I would like to use MQTT over SSL in my setup, but whenever I send MQTT SSL-related commands through the serial UART, I always receive an ERROR response.
Could you please provide the required menuconfig settings to enable SSL support? Additionally, I would appreciate it if you could share the documentation for MQTT SSL AT Commands.
Download Flash Firmware Link https://docs.espressif.com/projects/esp ... le_it.html
LOG:
AT+GMR
AT version:4.2.0.0-dev(s-8a71d66 - ESP32C2 - Jul 30 2025 07:10:44)
SDK version:v5.4.1-643-g8ad0d3d8f2-dirty
compile time(f57d9667):Aug 21 2025 15:33:30
Bin version:v4.2.0.0-dev(ESP32C2-2MB)
OK
AT+CERTADD
ERROR
AT+SSLx
ERROR
AT+SSLx?
ERROR
AT+SSLx=?
ERROR
AT+CERTADD?
ERROR
AT+CERTADD=?
ERROR
I think this build does not support SSL. Please provide me the steps to enable SSL in menuconfig, or share the latest SSL-supported build link for my ESP32 chip.
Shivam K
esp-at
Re: Issue with MQTT SSL AT Command Response on ESP8684H2 Firmware
Postby esp-at » Thu Sep 04, 2025 7:30 am
There is no a `AT+CERTADD` command. Please refer to examples:
- ssl client example: https://docs.espressif.com/projects/esp ... connection
- mqtt example: https://docs.espressif.com/projects/esp ... mples.html
Shivam_Kachhatiya
Postby Shivam_Kachhatiya » Mon Sep 08, 2025 10:58 am
Thank you for your response. I would like to clarify how to use SSL with a root/CA certificate on the ESP32 using AT commands. Could you please provide guidance or an example on how to configure the ESP32 AT firmware to connect to an MQTT broker over SSL using a root certificate for server verification?
Specifically, I want to understand:
How to upload or set the root certificate on the ESP32.
Which AT commands need to be used to enable SSL with server certificate verification.
Any minicontig settings required to enable SSL support in the firmware.
Thank you for your support.
Best regards,
Shivam
esp-at
Postby esp-at » Wed Sep 10, 2025 2:23 am
You can read/write/erase all the configurations of esp-at via `AT+SYSMFG` command. (includes certificates and keys)
https://docs.espressif.com/projects/esp ... cmd-sysmfg
About the server verification, different command has different parameter. In your MQTT case, you can configure the <scheme> parameter of `AT+MQTTUSERCFG`.
Shivam_Kachhatiya
Postby Shivam_Kachhatiya » Sat Sep 13, 2025 7:10 am
AT+CWJAP="Niks","niks@1989"
WIFI DISCONNECT
WIFI CONNECTED
WIFI GOT IP
OK
AT+SYSMFG=2,"server_cert","server_cert.0",7,1358
OK
OK
AT+MQTTUSERCFG=0,3,"ESH01_EACC40B3E412","ESH01_EACC40B3E412","SaskenSilicon@123",0,0,""
OK
AT+CIPSNTPCFG=1,0,"pool.ntp.org","time.nist.gov","in.pool.ntp.org"
OK
+TIME_UPDATED
AT+CIPSNTPTIME?
+CIPSNTPTIME:Sat Sep 13 07:06:40 2025
OK
AT+MQTTCONN=0,"o221126e.ala.us-east-1.emqxsl.com",8883,1
+MQTTDISCONNECTED:0
tried this command, but the connection failed. Can you suggest the steps for MQTT over TLS with a server certificate? I read back the certificate after writing, and it verifies correctly
Shivam
esp-at
Postby esp-at » Sun Sep 28, 2025 8:30 am
server_cert is not the right namespace for MQTT. you should use the following command to update mqtt ca:
AT+SYSMFG=2,"mqtt_ca","mqtt_ca.0",7,1358
Sorry that the document is not clear enough, we should add more description for this part.
Shivam_Kachhatiya
Postby Shivam_Kachhatiya » Fri Oct 03, 2025 7:26 am
[2025-10-03_12:53:08:222]AT
[2025-10-03_12:53:08:222]OK
[2025-10-03_12:53:10:661]AT+GMR
[2025-10-03_12:53:10:661]AT version:4.2.0.0-dev(s-8a71d66 - ESP32C2 - Jul 30 2025 07:10:44)
[2025-10-03_12:53:10:691]SDK version:v5.4.1-643-g8ad0d3d8f2-dirty
[2025-10-03_12:53:10:691]compile time(f57d9667):Sep 26 2025 14:55:36
[2025-10-03_12:53:10:691]Bin version:v4.2.0.0-dev(ESP32C2-2MB)
[2025-10-03_12:53:10:691]OK
[2025-10-03_12:53:12:458]AT+CWMODE=1
[2025-10-03_12:53:12:458]OK
[2025-10-03_12:53:14:191]AT+CWJAP="Niks","niks@1989"
[2025-10-03_12:53:14:191]WIFI DISCONNECT
[2025-10-03_12:53:14:300]WIFI CONNECTED
[2025-10-03_12:53:15:348]WIFI GOT IP
[2025-10-03_12:53:15:348]OK
[2025-10-03_12:53:19:707]AT+CIPSNTPCFG=1,0,"pool.ntp.org","time.nist.gov","in.pool.ntp.org"
[2025-10-03_12:53:19:723]OK
[2025-10-03_12:53:20:534]+TIME_UPDATED
[2025-10-03_12:53:23:129]AT+CIPSNTPTIME?
[2025-10-03_12:53:23:129]+CIPSNTPTIME:Fri Oct 3 07:23:23 2025
[2025-10-03_12:53:23:129]OK
[2025-10-03_12:53:26:018]AT+SYSMFG=2,"mqtt_ca","mqtt_ca.0",7,1358
[2025-10-03_12:53:26:034]OK
[2025-10-03_12:53:26:034]>
[2025-10-03_12:53:28:208]OK
[2025-10-03_12:53:38:223]AT+MQTTUSERCFG=0,3,"ESH01_EACC40B3E412","saskenIoT","SaskenSilicon2808",0,0,""
[2025-10-03_12:53:38:223]OK
[2025-10-03_12:53:45:879]AT+MQTTCONN=0,"o221126e.ala.us-east-1.emqxsl.com",8883,1
[2025-10-03_12:53:47:910]+MQTTDISCONNECTED:0
[2025-10-03_12:53:52:910]
[2025-10-03_12:53:52:910]ERROR
Note : Same Certificate and URL is working with cellular NbIOT Protocol
Please let me know any step is missing durring MQTT SSL connection.
Shivam
Shivam_Kachhatiya
Postby Shivam_Kachhatiya » Tue Oct 07, 2025 4:37 am
[2025-10-03_13:04:00:560]AT+CWJAP="Niks","niks@1989"
[2025-10-03_13:04:00:576]WIFI DISCONNECT
[2025-10-03_13:04:00:752]WIFI CONNECTED
[2025-10-03_13:04:01:792]WIFI GOT IP
[2025-10-03_13:04:01:792]OK
[2025-10-03_13:04:02:639]AT+MQTTCLEAN=0
[2025-10-03_13:04:02:639]OK
[2025-10-03_13:04:05:069]AT+SYSMFG=2,"mqtt_ca","mqtt_ca.0",7,1358
[2025-10-03_13:04:05:069]OK
[2025-10-03_13:04:05:069]>
[2025-10-03_13:04:08:272]OK
[2025-10-03_13:04:13:362]AT+CIPSNTPCFG=1,0,"pool.ntp.org","time.nist.gov","in.pool.ntp.org"
[2025-10-03_13:04:13:362]OK
[2025-10-03_13:04:14:820]+TIME_UPDATED
[2025-10-03_13:04:15:703]AT+CIPSNTPTIME?
[2025-10-03_13:04:15:703]+CIPSNTPTIME:Fri Oct 3 07:34:15 2025
[2025-10-03_13:04:15:703]OK
[2025-10-03_13:04:19:197]AT+MQTTUSERCFG=0,4,"ESH01_EACC40B3E412","saskenIoT","SaskenSilicon2808",0,0,""
[2025-10-03_13:04:19:213]OK
[2025-10-03_13:04:24:320]AT+MQTTCONN=0,"o221126e.ala.us-east-1.emqxsl.com",8883,1
[2025-10-03_13:04:27:340]+MQTTCONNECTED:0,4,"o221126e.ala.us-east-1.emqxsl.com","8883","",1
[2025-10-03_13:04:27:340]OK
[2025-10-03_13:06:24:938]AT+MQTTSUB=0,"exa/v1/c2d/ESH01E4153116714D",0
[2025-10-03_13:06:24:938]OK
[2025-10-03_13:06:49:849]AT+MQTTPUBRAW=0,"exa/v1/d2c/ESH01E4153116714D",5,0,0
[2025-10-03_13:06:49:849]OK
[2025-10-03_13:06:49:849]>+MQTTPUB:OK
[2025-10-03_13:07:38:498]AT+MQTTPUBRAW=0,"exa/v1/d2c/ESH01E4153116714D",5,0,0
[2025-10-03_13:07:38:498]OK
[2025-10-03_13:07:38:498]>+MQTTPUB:OK
This process works as described above, but sometimes I notice that the time sync command response is delayed, which causes a connection issue. Is there a command to directly set the time on the module?
Shivam K
esp-at
Postby esp-at » Thu Oct 16, 2025 3:48 am
Yes, you can set module time via AT+SYSTIMESTAMP command:
https://docs.espressif.com/projects/esp ... time-stamp
