Why do I keep popping my XIOA ESP32-C3's?
Sunbelt57
Postby Sunbelt57 » Thu Sep 04, 2025 4:27 pm
I've popped 3 just today so far. Here's my flash script:
idf.py -p /dev/ttyAMC0 flash
I'm trying to use the espnow example: esp-idf/examples/wifi/espnow_basic_example-master/espnow_basic_slave
All I know is that after I flash it, I try to run the monitor program or get onto the serial port and nothing happens. I've had this happen to 2 other XIOA chips too.
Sunbelt57
Re: Why do I keep popping my XIOA ESP32-C3's?
Postby Sunbelt57 » Thu Sep 04, 2025 4:29 pm
Actually, it's supposed to be /dev/ttyACM0
Postby Sprite » Fri Sep 05, 2025 12:28 am
Have you tried resetting the board after you flash it? If you get them into bootloader mode using the 'boot' button, that is needed to get them running again.
Sunbelt57
Postby Sunbelt57 » Sun Sep 07, 2025 3:53 pm
It seems you have to 1) hold the boot button down, 2) press and release the reset button, 3) release the boot button.
Funny thing is, I never had to do that before. Something must have changed. I have several others I could try.
Postby Sprite » Mon Sep 08, 2025 2:43 am
Potentially you're trying to reconfigure GPIO18/19. Those are the pins the USB connection runs on, so if you reconfigure those, you can't put the chip into download mode via USB anymore.
Sunbelt57
Postby Sunbelt57 » Tue Sep 09, 2025 8:41 pm
Not sure I understand. I'm not doing anything with GPIO18/19. At least not explicitly in my code.
RandomInternetGuy
Postby RandomInternetGuy » Thu Sep 18, 2025 1:06 pm
Once you look at the code that manages this, it's easy to remember this button salute.
1 sets a strapping pin - it's just a GPIO register that's configured as an input.
2 sets and releases the reset line. The SOC is then off to the races. Just before it does a jump into user flash, it polls that GPIO register with the boot button. There's a line in the boot ROM that's essentially:
if (button_held) goto boot room else goto flash monitor/downloader
3 is so your finger isn't on that button forever. :-)
There's no magic of using that pin for an address line or anything that clever.
Back to the original question, some boards do dumb things with the reset circuit that cause them to be unreliable with the normal esptool-generated reset. There are various states you can get the hardware into, such as remapping the GPIO for the boot console or generally wedging the USB/JTAG controller, that can slso get these stuck. Whacking the reset line is the sure thing.
Users browsing this forum: Qwantbot and 3 guests
