SoftAP + Mesh
MikeWazowski
SoftAP + Mesh
Postby MikeWazowski » Fri Apr 12, 2019 8:19 am
Is it possible to run a mesh network without a router and have each node as access point so that a phone could connect to them?
Combining softAP and mesh examples resulted in mesh running normally and an access point occasionally appearing with some number as SSID (not the one defined in my application) and I was not able to authentificate and connect to it.
Found a topic claiming it is impossible to achieve such behaviour, but MDF has been released since, so it may have changed by now:
https://github.com/espressif/esp-idf/issues/2260
ungodlydax
Re: SoftAP + Mesh
Postby ungodlydax » Mon Sep 15, 2025 12:15 pm
I'm working on a school project and i just ran into the same issue.😭😭😭😭
