when testing RF tx characteristics at different temperatures we see that the output power and EVM values drift out of spec.
Ambient temperature changes and/or heavy RF activity will cause this. We test temperatures from -40C to +85C.
If the device is reset RF calibration is done and characteristics are ok again.
This behavior is seen in the attached screen dumps from measurements. At -40C the
the instrument can't even recognize the signal/data rate.
Normal room temperature, good signal:
Low temperature, bad signal:
Low temperature after reset, good signal:
For the test we use the test commands:
fcc_mode_sel 2
wifitxout 6 0xc 12 (channel 6, data rate 54Mbps, Attenuation 3dB)
Is there any way run the calibration periodically or automatically when temperature changes.
Can calibration be initiated from the application?
Best regards,
Ola
Wi-Fi RF characteristics are not stable over temperature variations
- -40C before reset
- NINA-W131 #311 Wi-Fi Char 54Mbit -40C.png (219.81 KiB) Viewed 8319 times
- -40C after reset
- NINA-W131 #311 Wi-Fi Char 54Mbit -40C (after reset).png (219.63 KiB) Viewed 8319 times
- 25C
- NINA-W131 #311 Wi-Fi Char 54Mbit 25C.png (208.41 KiB) Viewed 8319 times
Re: Wi-Fi RF characteristics are not stable over temperature variations
Fyi, most engineers still are on holiday here... We'll look into this after the weekend.
What hardware are you testing? Wroom32 module?
Sorry that the problem does exist, because the RF test firmware has no periodic calibration function, it is a continuous package mode.
The SDK has periodic calibration functions that are not affected by temperature.
Currently the periodic calibration interface does not exist in the RF test firmware. But we will provide it in the future after verification.
Thanks for your interest in ESP32!
Users browsing this forum: Baidu [Spider], Bytespider, PerplexityBot, Qwantbot and 2 guests
