Esp32s3 not enetering main
KOTerra
Postby KOTerra » Wed Nov 05, 2025 7:33 am
Hello!
I have troubles trying to run this example
https://github.com/badlogic/mcugdx/tree ... les%2Fdoom
My board is an esp32s3-wroom-1devkit with 16MB flash and 8MB PSRAM. It has 2 usb c ports.
It builds and loads in esp idf but the main function doesn't start. No log printf, or even led blink from the top of main is called, neither the tft display itself starts showing frames.
This is the only output i get
mihaistoica@mmbp doom % '/Users/mihaistoica/.espressif/python_env/idf5.5_py3.13_env/bin/python' '
/Users/mihaistoica/esp/v5.5.1/esp-idf/tools/idf_monitor.py' -p /dev/tty.usbmodem1101 -b 115200 --
toolchain-prefix xtensa-esp32s3-elf- --make ''/Users/mihaistoica/.espressif/python_env/idf5.5_py3
.13_env/bin/python' '/Users/mihaistoica/esp/v5.5.1/esp-idf/tools/idf.py'' --target esp32s3 '/User
s/mihaistoica/REPOSITORIES/mcugdx/examples/doom/build/doom.elf'
--- Warning: Serial ports accessed as /dev/tty.* will hang gdb if launched.
--- Using /dev/cu.usbmodem1101 instead...
--- esp-idf-monitor 1.8.0 on /dev/cu.usbmodem1101 115200
--- Quit: Ctrl+] | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0xb (SPI_FAST_FLASH_BOOT)
Saved PC:0x40049aea
--- 0x40049aea: esp_rom_spiflash_read_status in ROM
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fce2820,len:0x1700
load:0x403c8700,len:0xe20
load:0x403cb700,len:0x31f8
entry 0x403c8938
I (24) boot: ESP-IDF v5.5.1-dirty 2nd stage bootloader
I (24) boot: compile time Nov  4 2025 23:28:29
I (25) boot: Multicore bootloader
I (25) boot: chip revision: v0.2
I (25) boot: efuse block revision: v1.3
I (25) qio_mode: Enabling QIO for flash chip MXIC
I (25) boot.esp32s3: Boot SPI Speed : 80MHz
I (25) boot.esp32s3: SPI Mode       : QIO
I (26) boot.esp32s3: SPI Flash Size : 16MB
I (26) boot: Enabling RNG early entropy source...
I (26) boot: Partition Table:
I (26) boot: ## Label            Usage          Type ST Offset   Length
I (27) boot:  0 nvs              WiFi data        01 02 00009000 00006000
I (27) boot:  1 phy_init         RF data          01 01 0000f000 00001000
I (27) boot:  2 factory          factory app      00 00 00010000 00100000
I (28) boot:  3 rofs             Unknown data     01 06 00110000 00e00000
I (28) boot: End of partition table
I (28) esp_image: segment 0: paddr=00010020 vaddr=3c020020 size=09d98h ( 40344) map
I (35) esp_image: segment 1: paddr=00019dc0 vaddr=3fc92d00 size=03154h ( 12628) load
I (37) esp_image: segment 2: paddr=0001cf1c vaddr=40374000 size=030fch ( 12540) load
I (40) esp_image: segment 3: paddr=00020020 vaddr=42000020 size=154f0h ( 87280) map
I (54) esp_image: segment 4: paddr=00035518 vaddr=403770fc size=0bbd8h ( 48088) load
I (63) esp_image: segment 5: paddr=000410f8 vaddr=50000000 size=00020h (    32) load
I (69) boot: Loaded app from partition at offset 0x10000
I (69) boot: Disabling RNG early entropy source...
W (70) flash HPM: HPM mode is optional feature that depends on flash model. Read Docs First!
W (71) flash HPM: HPM mode with DC adjustment is disabled. Some flash models may not be supported. Read Docs First!
W (71) flash HPM: High performance mode of this flash model hasn't been supported.
I tried every possible setting for the output CDC/UART/JTAG not working. Before disabling the Watchdog reset at boot it was constantly resetting so I narrowed it down to not entering in app_main()
I can provide the sdkcofing if necessary
Re: Esp32s3 not enetering main
Postby Sprite » Thu Nov 06, 2025 12:32 am
You probably need to disable this (likely in menuconfig).
Users browsing this forum: Baidu [Spider], ChatGPT-User, Google [Bot] and 1 guest
