Bricked M5Stack DINmeter
ted33414
Postby ted33414 » Tue Nov 04, 2025 6:07 am
Hi all..
So I got a (hopefully not) bricked DINmeter. It still connects to the PC but I cannot flash anything. It gives me the error: Invalid head of packet (0x08)
But its the same USB cable I used for flashing my first test library after which the display wouldnt turn on anymore. So it should work.
I am guessing I had the wrong board selected as I got confused. There are so many similar sounding names for these devices. M5stack, M5stampS3, ESP32, M5 DinMeter. I think I got the wrong one which caused this mess.
All I am trying to do now is to start over from scratch.
Any ideas?
Re: Bricked M5Stack DINmeter
Postby Sprite » Wed Nov 05, 2025 4:08 am
Try holding the G0 button when powering up the device; if the issue is something in flash, that should bypass it.
ted33414
Postby ted33414 » Fri Nov 07, 2025 9:52 pm
Thank you - I understand that will put the device into download mode right?
But once I am in download mode what firmware would I need to upload in order to get the device back to factory settings?
Postby Sprite » Sat Nov 08, 2025 12:10 am
Not sure, you'd have to ask M5Stack (or see if it's on their website)
ted33414
Postby ted33414 » Sat Nov 08, 2025 9:11 pm
I got it back to working!
Thank you, I downloaded the M5burner tool and could flash the userdemo using the download mode on the device..
its back to factory settings - I am so happy :)
Users browsing this forum: Bytespider, trendictionbot and 3 guests
