Miner V2 Has all Zeros In Hash
dcgtechnologies
Postby dcgtechnologies » Wed Nov 05, 2025 10:58 pm
I just configured my new miner with Nerd Miner V2 it is brand new one and the chipset is ESP32-32E N4 and it had an older version of the miner software version on it. Now that I have configured with Version 2 all I see is zeros all across the miner and it is pulling an IP Address from Linksys router. It worked previously on that and well now it is not working. Does anyone have any ideas? Anyone familiar with the chipset I posted? Thank you.
dcgtechnologies
Re: Miner V2 Has all Zeros In Hash
Postby dcgtechnologies » Thu Nov 06, 2025 7:21 pm
So I tried to install nerdminer V2 bin file fron Github and have zero luck with this thing. I used the Platformio with Visual Studios and did not get anywhere with this. I have a C3f4e9d4 Chipset Version 3 and I was trying to get this thing flashed correctly and just I am not getting anywhere. Can someone help out a newbie? I am really trying hard to learn this device as complicated as it sounds. Thank you.
MicroController
Postby MicroController » Fri Nov 07, 2025 3:12 pm
Make sure you use the correct firmware variant for the board/device you got.
dcgtechnologies
Postby dcgtechnologies » Sun Nov 09, 2025 5:45 am
Where can I find the correct firmware version for that board I have? Can you help me locate it? I can provide more detail if it is needed. Thank you for your reply.
MicroController
Postby MicroController » Mon Nov 10, 2025 8:24 am
More detail needed indeed. A link to the specific product you bought or pictures of the board would help.
Also the flashing/update procedure you used. A full flash erase may be needed prior to flashing a new firmware.
dcgtechnologies
Postby dcgtechnologies » Wed Nov 12, 2025 4:13 am
I actually traded it for another piece of technology and well here are the attached pictures of the miner and I used the flashing procedure from two sites. See below:
https://www.youtube.com/watch?v=nCaGVYx3rgo&t=502s and loaded the bin file "espnerdminer2.1.bin" from his process and rebooted and erased the flash.
I went to this site at https://solutions.carenuity.com/ went to the section for ESP32 board and clicked install and it works 100% and loads the bin file just fine, but when I connect it "Wifi" I can see the miner pull an IP Address from the DHCP server, but the display is all zeros including the hash.
So this is where I am stuck at and well, I hope to find the right bin file, but I think the correct bin file would probably fix my issues. I am very familiar with the esptool commands. Thank you for your help.
Bitcoin Miner - Display View.JPG (1.95 MiB) Viewed 3485 times
Bitcoin Miner - Back Side View.JPG (2.48 MiB) Viewed 3485 times
Last edited by dcgtechnologies on Fri Nov 14, 2025 9:39 pm, edited 1 time in total.
MicroController
Postby MicroController » Wed Nov 12, 2025 10:04 am
Did you also re-configure your mining pool details after flashing?
dcgtechnologies
Postby dcgtechnologies » Wed Nov 12, 2025 9:39 pm
I did put my wallet address in the bitcoin address field as well but same result each time. Is there something else I need to look for or configure?
MicroController
Postby MicroController » Fri Nov 14, 2025 9:54 am
If the firmware runs successfully, indicated by the display working and you being able to access the web interface, the issue is likely in the specifics of the firmware and/or the way it needs to be set up; like https://github.com/BitMaker-hub/NerdMiner_v2/issues/431 for example.
dcgtechnologies
Postby dcgtechnologies » Fri Nov 14, 2025 9:37 pm
Although a great reference link that issue is something fixed over a year ago and well mine has to got to be past that now I would hope. Can you tell me what bin file I would need to load on to this miner? See the attached screenshots of what I am seeing. I can ping the device on the network and get a reply back but cannot reach the configuration page. So, I was narrowing it down to the wrong firmware. There is not much support out there for these devices I see.
Screen 1 - Displaying Current Block.JPG (2.59 MiB) Viewed 3433 times
Screen 1 - Zero Hash.JPG (2.57 MiB) Viewed 3435 times
Users browsing this forum: Amazon [Bot], Barkrowler, Bytespider and 5 guests
