I am a bit confused by the documentation for the ESP32S3 N8R16 devkit boards. These boards have 2 USB-C connectors on the side away from the processor and the reset/boot buttons up near the processor. I think they are devkitc-1.1 boards. I am attaching them to a 4 layer PCB, so it would be very hard to re-route the signals if I am using the wrong GPIOs.
My questions are:
1. Can I use GPIO 12 and 13 for an I2C bus? Some references say GPIO 12 is a boot strapping pin, others say OK.
2. What are the internal pullups for these two pins? I want to make sure I have the right level of pullups on these two lines. Some references say GPIO 13 is only for SDI bus, and has no pullup, others say OK.
Can I use GPIO 12 and 13 for I2C bus?
Re: Can I use GPIO 12 and 13 for I2C bus?
1. There are no constraints for GPIO12, GPIO13 so its safe to use them for i2c
Strapping pins for S3 are, according to the datasheet, GPIO 0, 3 45 and 46
2. Internal pull-up/down, according to the same data sheet is 45k, so too high for I2C
