Can I use GPIO 12 and 13 for I2C bus?
pmi2410
Postby pmi2410 » Wed Nov 19, 2025 5:58 pm
I am a bit confused by the documentation for the ESP32S3 N8R16 devkit boards. These boards have 2 USB-C connectors on the side away from the processor and the reset/boot buttons up near the processor. I think they are devkitc-1.1 boards. I am attaching them to a 4 layer PCB, so it would be very hard to re-route the signals if I am using the wrong GPIOs.
My questions are:
1. Can I use GPIO 12 and 13 for an I2C bus? Some references say GPIO 12 is a boot strapping pin, others say OK.
2. What are the internal pullups for these two pins? I want to make sure I have the right level of pullups on these two lines. Some references say GPIO 13 is only for SDI bus, and has no pullup, others say OK.
ves011
Contact:
Re: Can I use GPIO 12 and 13 for I2C bus?
Postby ves011 » Wed Nov 19, 2025 7:27 pm
1. There are no constraints for GPIO12, GPIO13 so its safe to use them for i2c
Strapping pins for S3 are, according to the datasheet, GPIO 0, 3 45 and 46
2. Internal pull-up/down, according to the same data sheet is 45k, so too high for I2C
pmi2410
Postby pmi2410 » Wed Nov 19, 2025 10:17 pm
Thanks!
Users browsing this forum: Bytespider, trendictionbot and 3 guests
