ESP32 EN pin pulled down
Avro Biswas
Re: ESP32 EN pin pulled down
Postby Avro Biswas » Mon Nov 24, 2025 11:16 pm
The capacitor is faulty!
The 1µF capacitor between the EN (enable) pin and GND (ground) is defective. Initially, it shows high resistance, but eventually shorts to ground. If you have a capacitor that handles contact debouncing, inspect it carefully. If possible, remove it and see if the ESP boots up normally.
Postby Sprite » Tue Nov 25, 2025 9:04 am
That'd do it. Fyi, it means the board probably had some mechanical trauma, causing the ceramic capacitor to crack. If the layers of conductive and non-conductive material then aligns up just right, both sides will be connected and the capacitor will short out.
Users browsing this forum: Baidu [Spider] and 2 guests
