Hello:
Is there a way I can store WiFi information in flash memory such that I can reconnect to my router upon a reboot more quickly?
After I successfully connect to my WiFi, then press reset or download new code, (ESP8266 in this case) sometimes it takes a couple of minutes to reconnect.
It prints "connecting to <my WiFi>" then prints some periods, then says "Failed to connect."
I sit in a forever loop here until it connects which sooner or later it does.
Sometimes it takes 10 or 15 times.
I have read about "WiFi.setAutoReconnect(true);" and "WiFi.persistent(true);" but these things say they should be set AFTER the WiFi is connected to the router.
I have tried these things to no avail.
Thanks, Mark.
Reconnect to WiFi more quickly
lichurbagan
Re: Reconnect to WiFi more quickly
Use the ESP8266’s built-in WiFi storage. Don’t pass credentials every boot. Set:
This uses saved credentials. It reconnects much faster. Passing SSID and password forces a full scan. That causes long delays. A static IP helps too. It skips DHCP. Avoid forever loops that block tasks. Let auto-reconnect run in the background. This setup usually reconnects in under one second.
WiFi.mode(WIFI_STA);
WiFi.begin(); // no arguments
Cool Javelin
Thank you lichurbagan:
This seems to work better.
Now I need to call WiFi.begin(ssid,passwd) or WiFi.begin() depending if this is a first time call, or subsequent call.
I will do more research on this, I think I'd like to use the later, then if that fails, use the former. But since it is now working, it will go a little lower on the priority list.
Mark.
Mark.
Cool Javelin
I did a revamp of my "connect to wifi" routines, I think this may be the best of both worlds.
MyWiFi.h
WiFi constants, variables, and procedures
#ifndef _MyWiFi_H
#define _MyWiFi_H
#define RECONNECT_TO_WIFI true
#define ANEW_CONNECT_TO_WIFI false
#define NB_TRYWIFI 10
// provide text for the WiFi mode
const char *str_mode[]= { "WIFI_OFF", "WIFI_STA", "WIFI_AP", "WIFI_AP_STA" };
const char *str_status[]= {
"WL_IDLE_STATUS",
"WL_NO_SSID_AVAIL",
"WL_SCAN_COMPLETED",
"WL_CONNECTED",
"WL_CONNECT_FAILED",
"WL_CONNECTION_LOST",
"WL_DISCONNECTED"
void ShowWifiStatus(void) {
Serial.print ("Connected to: "); // show some info to the user
Serial.print (WiFi.SSID());
Serial.print (", as: ");
Serial.print (NODENAME);
Serial.print (". Mode: ");
Serial.print (str_mode[WiFi.getMode()]);
Serial.print (", IP address: ");
Serial.print (WiFi.localIP());
Serial.print (", MAC: ");
Serial.println(WiFi.macAddress());
bool WifiGotConnected(int _try) {
while ((WiFi.status() != WL_CONNECTED) && (_try < NB_TRYWIFI)) { // sit here till we are connected
Serial.print("."); // let the user know we are working on it
delay(500); // wait 1/2 second
_try++; // and bump try count
if ( _try >= NB_TRYWIFI ) { // did we exceed our wait time?
Serial.println("Didn't connect to WiFi this time.");
return(false);
return(true); // we got connected
bool StartWifi(bool re_conn, const char *ssid, const char * password, const char *our_name) {
int _try = 0; // the connection attempt retry count
Serial.print("Connecting to "); // tell user we are connecting
Serial.print (ssid); // to this router
Serial.print(" - "); // tell user we are connecting
// use in case of mode problem (should be redundant)
// switch to Station mode (also likely unneeded)
if (WiFi.getMode() != WIFI_STA) {
WiFi.disconnect();
WiFi.hostname(our_name); // tell the router who we are
WiFi.persistent(true); // reconnect if possabile
WiFi.setAutoReconnect(true); // auto reconnect if disconnected
WiFi.mode(WIFI_STA); // not an access point
// if we want to re connect
if (re_conn) {
Serial.println("Trying to REconnect.");
WiFi.begin(); // no arguments, connect to last router
// now wait for a connection
if (WifiGotConnected(_try)) {
Serial.println("REconnection Successful");
ShowWifiStatus();
return(true);
// If we want a new connection or we didn't reconnect, supply credentials
Serial.println("Trying to connect anew.");
WiFi.begin(ssid, password);
Serial.println("ANEW connection Successful");
ShowWifiStatus();
return(true);
// we did not connect or REconnect...
Serial.println("Cannot connect to WiFi network.");
return(false);
#endifWho is online
Users browsing this forum: Qwantbot, YisouSpider and 12 guests
