i2c not working, v5.5.2, Sensirion SHCT3 module
atx823
Postby atx823 » Sun Jan 25, 2026 9:14 pm
A very simple example. The SHCT3 device seems to add ok, but the first sleep command fails on transmit with ESP_ERR_TIMEOUT.
The SHTC3 is an Adafruit module with 10k external pullups, powered from the esp32's 3.3v rail (pico-04 from digikey). This same hardware and circuit has been working for years with v5.1.4 and the old driver. It stopped working reliably with v5.2.3, so I wrote this code for the new driver using v5.5.2 and have not got it to work.
Any ideas?
#include <stdio.h>
#include <stdbool.h>
#include <string.h>
#include <math.h>
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_wifi.h"
#include <sys/param.h>
#include "esp_log.h"
#include "esp_timer.h"
#include "driver/gpio.h"
#include "driver/i2c_master.h"
#define SHTC3_ADDR 0x70
#define PIN_SHTC3_POWER	GPIO_NUM_19
#define PIN_SDA			GPIO_NUM_21
#define PIN_SCL			GPIO_NUM_22
uint32_t const appVersion = 2601232;
static uint8_t Shtc3_cmdSleep[] = {0xB0, 0x98};
static uint8_t Shtc3_cmdWake[] = {0x35, 0x17};
static uint8_t Shtc3_cmdReadClockStretched[] = {0x7C, 0xA2};
static esp_err_t i2cBusStart(i2c_master_bus_handle_t *bus) {
	esp_log_write(ESP_LOG_INFO, "Airmon", "i2c_new_master_bus\n");
	i2c_master_bus_config_t bus_cfg = {
		.i2c_port = I2C_NUM_0,
		.sda_io_num = PIN_SDA,
		.scl_io_num = PIN_SCL,
		.clk_source = I2C_CLK_SRC_DEFAULT,
		.glitch_ignore_cnt = 7,
		.flags.enable_internal_pullup = false,
	return i2c_new_master_bus(&bus_cfg, bus);
static esp_err_t addDevice(i2c_master_bus_handle_t bus, uint8_t addr, i2c_master_dev_handle_t *dev) {
	esp_log_write(ESP_LOG_INFO, "Airmon", "i2c_master_bus_add_device\n");
	i2c_device_config_t dev_cfg = {
		.dev_addr_length = I2C_ADDR_BIT_LEN_7,
		.device_address = addr,
		.scl_speed_hz = 10000,
	return i2c_master_bus_add_device(bus, &dev_cfg, dev);
static bool shtc3Sleep(i2c_master_dev_handle_t dev) {
	esp_err_t err = i2c_master_transmit(dev, Shtc3_cmdSleep, sizeof(Shtc3_cmdSleep), pdMS_TO_TICKS(20));
	esp_log_write(ESP_LOG_INFO, "Airmon", "i2c_master_transmit sleep=%d\n", err);
	return err == ESP_OK;
static bool shtc3Cycle(i2c_master_dev_handle_t dev) {
	esp_err_t err;
	err = i2c_master_transmit(dev, Shtc3_cmdWake, sizeof(Shtc3_cmdWake), pdMS_TO_TICKS(20));
	esp_log_write(ESP_LOG_INFO, "Airmon", "shtc3 wake err=%d\n", err);
	if (err != ESP_OK) return false;
	int64_t x = esp_timer_get_time();
	while((esp_timer_get_time() - x) < 240);
	uint8_t recvBuf[6];
	err = i2c_master_transmit_receive(dev, Shtc3_cmdReadClockStretched, sizeof(Shtc3_cmdReadClockStretched), (uint8_t *)recvBuf, sizeof(recvBuf), pdMS_TO_TICKS(1000));
	esp_log_write(ESP_LOG_INFO, "Airmon", "shtc3 read err=%d\n", err);
	esp_log_write(ESP_LOG_INFO, "Airmon", "shtc3 sleep err=%d\n", err);
	return (err == ESP_OK);
void app_main(void) {
	esp_log_write(ESP_LOG_INFO, "Airmon", "Airmon_v552c app_main start v%ld\n", appVersion);
	esp_log_level_set("gpio", ESP_LOG_VERBOSE);
	esp_log_level_set("i2c",  ESP_LOG_VERBOSE);
	vTaskDelay(pdMS_TO_TICKS(100));
	i2c_master_bus_handle_t bus = NULL;
	i2c_master_dev_handle_t shtc3 = NULL;
	if (i2cBusStart(&bus) == ESP_OK) {
		if (addDevice(bus, SHTC3_ADDR, &shtc3) == ESP_OK) {
			if (shtc3Sleep(shtc3)) {
				bool ok;
				do {
					vTaskDelay(pdMS_TO_TICKS(3000));
					ok = shtc3Cycle(shtc3);
				} while(ok);
				esp_log_write(ESP_LOG_INFO, "Airmon", "shtc3Cycle failed\n");
			} else {
				esp_log_write(ESP_LOG_INFO, "Airmon", "initial sleep failed\n");
			esp_log_write(ESP_LOG_INFO, "Airmon", "deleting shtc3\n");
			if (i2c_master_bus_rm_device(shtc3) != ESP_OK) esp_log_write(ESP_LOG_INFO, "Airmon", "i2c_master_bus_rm_device failed\n");
		} else {
			esp_log_write(ESP_LOG_INFO, "Airmon", "addDevice failed\n");
		esp_log_write(ESP_LOG_INFO, "Airmon", "stopping bus\n");
		if (i2c_del_master_bus(bus) != ESP_OK) esp_log_write(ESP_LOG_INFO, "Airmon", "i2c_del_master_bus failed\n");
		bus = NULL;
	} else {
		esp_log_write(ESP_LOG_INFO, "Airmon", "i2cBusStart failed\n");
atx823
Re: i2c not working, v5.5.2, Sensirion SHCT3 module
Postby atx823 » Fri Jan 30, 2026 1:19 am
needed to add .scl_wait_us = 12300 to the device config, and xfer_timeout_ms = 30 for i2c_master_transmit_receive
Users browsing this forum: No registered users and 8 guests
