Hi, I see a FFT functions in the Espressif DSP Library at :
https://docs.espressif.com/projects/esp ... s.html#fft
However, it is unclear which functions are forward or backward FFT / iFFT. The documentation is very unhelpful and there are no examples given.
Can anyone provide application examples of FFT / iFFT?
Thank you
FFT - iFFT
Re: FFT - iFFT
Where have you looked? What did you find? (Google.com ?)
Tom
Tom
IT Professional, Maker
Santiago, Dominican Republic
Re: FFT - iFFT
For complex numbers you can use the FFT for the IFT:
ift = conjugate, fft, conjugate, scale
Check a math book for details.
Re: FFT - iFFT
That's an idea; thank you. It requires unanticipated work and it should be in ASM to be fully optimized. Most other DSP suppliers have already solved that problem and written a proper iFFT for their libraries.
Re: FFT - iFFT
Sorry for restarting an old thread. I am aware we can do:
IFFT(data) = 1/N * conj(FFT(conj(data)))
However for efficiency a dedicated IFFT function would be better. Looking at the math the difference other than the 1/N scaling factor is as "simple" as a sign flip for the exponent of "e" from (-jwt) into (+jwt). Now looking at the dsps_fft2r_fc32_aes3 assembly (as ESP32-S3 is my target). The core processing block:
I'm pondering if it would be as simple as exchanging the msub.s and madd.s. The twiddle factors would be unchanged. Like this:
thoughts?
#include "dsps_fft2r_platform.h"
#if (dsps_fft2r_fc32_aes3_enabled == 1)
.text
.align 4
.global dsps_fft2r_fc32_aes3_
.type dsps_fft2r_fc32_aes3_,@function
dsps_fft2r_fc32_aes3_:
//esp_err_t dsps_fft2r_fc32_ansi(float *data, int N, float* dsps_fft_w_table_fc32)
entry a1, 16
// Array increment for floating point data should be 4
// data - a2
// N - a3
// dsps_fft_w_table_fc32 - a4
// a6 - k, main loop counter; N2 - for (int N2 = N/2; N2 > 0; N2 >>= 1)
// a7 - ie
// a8 - j
// a10 - (j*2)<<2, or a10 - j<<3
// f0 - c or w[2 * j]
// f1 - s or w[2 * j + 1]
// a11 - ia
// a12 - m
// a13 - ia pointer
// a14 - m pointer
// f6 - re_temp
// f7 - im_temp
srli a6, a3, 1 // a6 = N2 = N/2
movi.n a7, 1 // a7 - ie
.fft2r_l1:
movi.n a8, 0 // a8 - j
movi.n a11,0 // a11 = ia = 0;
.fft2r_l2: // loop for j, a8 - j
addx8 a10, a8, a4 // a8 - shift for cos () -- c = w[2 * j]; -- pointer to cos
ee.ldf.64.ip f1, f0, a10, 0
add.n a12, a11, a6 // a12 = m = ia + N2
addx8 a14, a12, a2 // a14 - pointer for m*2
loopnez a6, .fft2r_l3
ee.ldf.64.ip f5, f4, a14, 0 // data[2 * m], data[2 * m + 1]
mul.s f6, f0, f4 // re_temp = c * data[2 * m]
mul.s f7, f0, f5 // im_temp = c * data[2 * m + 1]
addx8 a13, a11, a2 // a13 - pointer for ia*2
ee.ldf.64.ip f3, f2, a13, 0 // data[2 * ia], data[2 * ia + 1]
madd.s f6, f1, f5 // re_temp += s * data[2 * m + 1]; // <---------- add the w term
msub.s f7, f1, f4 // im_temp -= s * data[2 * m]; // <------------- subtracting the w term
addi a11, a11, 1 // ia++
sub.s f8, f2, f6 // = data[2 * ia] - re_temp;
sub.s f9, f3, f7 // = data[2 * ia + 1] - im_temp;
add.s f10, f2, f6 // = data[2 * ia] + re_temp;
add.s f11, f3, f7 // = data[2 * ia + 1] + im_temp;
ee.stf.64.ip f9, f8, a14, 0
ee.stf.64.ip f11, f10, a13, 0
.fft2r_l3:
add.n a11, a11, a6
addi.n a8, a8, 1 // j++
bne a8, a7, .fft2r_l2
slli a7, a7, 1 // ie = ie<<1
// main loop: for (int k = N/2; k > 0; k >>= 1)
srli a6, a6, 1 // a6 = a6>>1
bnez a6, .fft2r_l1 // Jump if > 0
movi.n a2, 0 // return status ESP_OK
retw.n
#endif // dsps_fft2r_fc32_aes3_enabled
msub.s f6, f1, f5 // re_temp -= s * data[2 * m + 1];
madd.s f7, f1, f4 // im_temp += s * data[2 * m]; thoughts?
MicroController
Re: FFT - iFFT
You may want to check out esp-dl's FFT:
https://components.espressif.com/compon ... if/dl_fft/
https://github.com/espressif/esp-dl/tre ... ols/dl_fft
Seems to have iFFT functions too.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 1 guest
