esp-idf/v6.0: CMake Error at ... components/mbedtls/mbedtls/tf-psa-crypto/core MISSING
Drohne
Postby Drohne » Fri Mar 13, 2026 12:44 pm
I'm with the lost FreeBSD community trying to get ESP-IDF running for small projects. A couple of days ago I did the last git fetch/rebase on IDF v6.0, everything worked so far. But as of today, another pull leaves the ESP-IDF tree corrupt:
CMake Error at /PATH/esp-idf-idf60/tools/cmake/component.cmake:321 (message):
Include directory
'/PATH/esp-idf-idf60/components/mbedtls/mbedtls/tf-psa-crypto/core'
is not a directory.
/PATH/esp-idf-idf60/tools/cmake/component.cmake:496 (__component_add_include_dirs)
/PATH/esp-idf-idf60/components/mbedtls/CMakeLists.txt:49 (idf_component_register)
This seems to me like another flaw of missing commits, the directory
does only contain 'doxygen' - nothing more. Everything required by the build framework ist missing ...
slazyhw
Re: esp-idf/v6.0: CMake Error at ... components/mbedtls/mbedtls/tf-psa-crypto/core MISSING
Postby slazyhw » Mon Mar 23, 2026 9:36 am
Same error here. Any progress on this?
slazyhw
Postby slazyhw » Mon Mar 23, 2026 11:24 am
Did you clone the entire esp-idf repository again or did you just switch to the new version tag in your old local copy?
mbedtls is a git submodule and I think that just switching the tag will not touch the submodules at all which would still fit your prior idf version.
Get a new, clean copy of the repo and then switch to the tag before your first build. That fixed it for me.
