Building EIM from Source for Windows
bewster
Postby bewster » Tue Mar 17, 2026 7:05 pm
I didn't want to create a GitHub issue, but unsure if this is a suitable forum for this type of question?
I am new to all this Rust and toolchain. So unsure if I am building, locally, correctly under Windows 11.
There might be some gaps in the documentation.
Checking out the master branch. I can get it to run the GUI application in development mode, using:
cargo tauri dev -- --bin eim
The issue I run into is starting the easy installation results in:
Error Details:
Installation failed with exit code: 101
INFO - Install process stdout:   [PASS] Python Version
INFO - Install process stdout:   [PASS] pip
INFO - Install process stdout:   [PASS] venv
INFO - Install process stdout:   [PASS] Standard Library (json, os, platform)
INFO - Install process stdout:   [PASS] ctypes
ERROR - Install process stderr:
INFO - Install process stdout:   [PASS] SSL/HTTPS
ERROR - Install process stderr: thread 'main' (7364) panicked at C:\Users\User\.cargo\registry\src\index.crates.io-1949cf8c6b5b557f\tokio-1.49.0\src\runtime\blocking\shutdown.rs:51:21:
INFO - Your Python meets the requirements
ERROR - Install process stderr: Cannot drop a runtime in a context where blocking is not allowed. This happens when a runtime is dropped from within an asynchronous context.
ERROR - Install process stderr: note: run with `RUST_BACKTRACE=1` environment variable to display a backtrace
I tried a build under WSL, and this works fine, no error.
FYI: I was trying to build from source, as I am having an issue with using the EIM to install on a specific corporate workstation - and thought by investigating the source I might be able to understand the issue I am having, and either fix or raise a related GitHub issue.
bewster
Re: Building EIM from Source for Windows
Postby bewster » Mon Mar 23, 2026 5:58 pm
I did create a GitHub issue, https://github.com/espressif/idf-im-ui/issues/590, and the result is it is a bug and not something I was doing wrong.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 1 guest
