Is there a USB host OTG library for the ESP32-P4?
For use with the Waveshare ESP32-P4 Basic Kit board under Arduino.
IDE 2.3.8, core 3.3.7
Thanks for your help.
USB Host OTG library for ESP32-P4
lbernstone
Re: USB Host OTG library for ESP32-P4
The Arduino library is a work in progress
The esp-idf library works fine under Arduino, but requires significant understanding of the protocol, and how to translate code from C to C++. USB-host examples
andromeda92
Thanks for your response.
I tried it on an Arduino using esp-idf, but not the examples from the link. It initializes the host correctly and is detected,
but the problem I'm encountering is that the keyboard isn't getting power.
I'm wondering if I need to enable a GPIO pin for USB power.
The board I'm using is a Waveshare ESP32-P4 Module Dev-Kit. It has four USB-A ports, and one seems to be dedicated to USB-HOST, connected directly to the two D+ and D- pins, but I have no idea about the power supply.
andromeda92
My question is why the Waveshare ESP32-P4 module dev-kit board is not sending 5V to the USB-A port?
