Hi all,
Can esp32 Arduino code be mixed with FreeRTOS code in 1 file (1project)?
Say one wants to use an arduino liquidcrystal_i2c, or neopixel library, but also use the two esp cores for working with interrupts and passing data from core2 (ESP32-IDF) to core1 (Arduino)
Grtz,
Yves
Mixing Adruino code and FreeRTOS code in one project
Re: Mixing Adruino code and FreeRTOS code in one project
Arduino for ESP32 is nothing more than a layer on FreeRTOS, so there are some ways to do this:
1- Calling freeRTOS functions in a Arduino code (this is the less optimized way)
2- Using arduino as IDF component, this will allow you to run arduino code on IDF, also use FreeRTOS functions too
3- Use arduino libs as C functions: some libraries are written in pure C and not depend of arduino core to run, so in some cases you can use them directly, or with few modifications, just be careful about thread safe stuff
