ESP32-S3 + LVGL + ILI9488: Reading .gif from SD card causes SPI transmit error (buffer size issue?)
phianhquan
Postby phianhquan » Fri Apr 10, 2026 10:32 am
I'm using ESP32-S3 with LVGL and an ILI9488 SPI display. I'm trying to display a GIF from SD card:
```c
lv_gif_set_src(img, "A:/example.gif");
### Issue
With full buffer:
```c
static const size_t LV_BUFFER_SIZE = DISPLAY_HORIZONTAL_PIXELS * DISPLAY_VERTICAL_PIXELS;
I get:
spi transmit (queue) color failed
Reducing buffer size (e.g. 40 lines) avoids the SPI error, but the GIF (~300KB) does not display correctly.
### Question
Is this due to SPI/DMA limits or GIF decoding constraints in LVGL?
What is the recommended way to display large GIFs from SD card on ESP32-S3?
Thanks!
MicroController
Re: ESP32-S3 + LVGL + ILI9488: Reading .gif from SD card causes SPI transmit error (buffer size issue?)
Postby MicroController » Mon Apr 13, 2026 3:36 pm
Or you're just running out of RAM?
