idf.py build progress showing percentage instead of line numbers
I have esp-idf 5.5.3 installed on two different machines. I might have installed them using the same procedure, I don't recall. But I did not set any special options or anything.
I've been through a lot of esp-idf upgrades and installs, and when I do an "idf.py build" it has always shown the progress as line number ([current-line / total-lines]). However, one of my two current installations has a different looking output. It's a bit more verbose but not nearly as verbose as using the -v option. Also, it shows progress as [XX %] instead of line numbers.
This is no big deal but I have a soft preference for the line numbers. Anyone know how to control what this output looks like? I read through the doc page for idf.py but didn't see anything about it.
nopnop2002
- Contact:
Re: idf.py build progress showing percentage instead of line numbers
Is it possible that the versions of ESP-IDF installed on the two PCs are different?
You can check the ESP-IDF version with this command.
$ idf.py --version
ESP-IDF v5.5.3-dirtyRe: idf.py build progress showing percentage instead of line numbers
Good question! They both show ESP-IDF v5.5.3.Is it possible that the versions of ESP-IDF installed on the two PCs are different?
You can check the ESP-IDF version with this command.Code: Select all
$ idf.py --version ESP-IDF v5.5.3-dirty
It seems like there must be some kind of option or something that drives this format of output. I've been through many ESP-IDF versions over the last few years and have never seen this particular build output format;
[ 31%] Building C object esp-idf/vfs/CMakeFiles/__idf_vfs.dir/vfs_eventfd.c.obj
[ 31%] Building C object esp-idf/vfs/CMakeFiles/__idf_vfs.dir/vfs_semihost.c.obj
[ 32%] Building C object esp-idf/vfs/CMakeFiles/__idf_vfs.dir/nullfs.c.obj
[ 32%] Linking C static library libvfs.a
nopnop2002
- Contact:
I don't know what caused it, but it's very interesting.
Is it possible that the versions of ninja installed on the two PCs are different?
$ ninja --version
1.11.1Re: idf.py build progress showing percentage instead of line numbers
Is it possible that my environment uses an alternative to ninja? It is not in one of my .espressif installations. This is the one that does percentages. This environment is Ubuntu running in a VirtualBox.I don't know what caused it, but it's very interesting.
Is it possible that the versions of ninja installed on the two PCs are different?Code: Select all
$ ninja --version 1.11.1
My other environment, which shows line numbers, is running ninja 1.12.1. It's native Ubuntu.
nopnop2002
- Contact:
Maybe so.Is it possible that my environment uses an alternative to ninja?
In environments where ninja is installed, idf.py use ninja.
`idf.py build` will display this:
Executing "ninja all"...
[4/1085] Generating ../../partition_table/partition-table.bin
Executing "make -j 6 all"...
[ 0%] Generating ../../partition_table/partition-table.bin
[ 1%] Generating project_elf_src_esp32.c
[ 1%] Generating /home/nop/rtos/version/build/esp-idf/esp_system/ld/sections.ld.in linker script...
[ 1%] Generating /home/nop/rtos/version/build/esp-idf/esp_system/ld/memory.ld linker script...
[ 1%] Built target custom_bundle
[ 1%] Built target _project_elf_src
[ 1%] Built target sections.ld.in
Try this on native Ubuntu.My other environment, which shows line numbers, is running ninja 1.12.1. It's native Ubuntu.
$ sudo apt remove --purge ninja-build
$ idf.py fullclean
$ idf.py build
$ sudo apt install ninja-build
$ idf.py fullclean
$ idf.py build
Thanks @nopnop2002. What you describe explains what I'm seeing. I don't recall doing anything but a "default" procedure installing ESP-IDF on either platform, but on the virtual box, it must have gone down the "make" path. It's functioning properly, so I may leave it be ("let a sleeping dog lie..." "if it ain't broke, don't fix it..." etc
Users browsing this forum: Baidu [Spider], Bytespider, ChatGPT-User, Semrush [Bot] and 3 guests
