deprecated function how to solve it
pdecaro
Postby pdecaro » Fri Apr 10, 2026 8:04 pm
Good evening, I'm having this problem. When I recompile a program that was working perfectly, I get this error for a deprecated function called "esp_lcd_touch_get_coordinates." It tells me to replace it with "esp_lcd_touch_get_data-Instead." I replace the name of this new function in the program, but I still get the error.
Can you please help me solve this problem?
Thank you.
MicroController
Re: deprecated function how to solve it
Postby MicroController » Mon Apr 13, 2026 8:27 am
I replace the name of this new function in the program, but ...
The new function has a different signature than the old one, i.e. it must be called with different arguments. Documentation seems to still be sparse, but here's an example:
esp_lcd_touch_point_data_t touch_point_data[1];
uint8_t touch_cnt = 0;
ESP_ERROR_CHECK(esp_lcd_touch_get_data(tp, touch_point_data, &touch_cnt, 1));
mbratch
Postby mbratch » Tue Apr 14, 2026 11:21 pm
Were you actually getting an error message for the deprecated function or was it a warning message? Usually when a function becomes deprecated, you're given a considerable amount of time to adapt the replacement function(s).
nopnop2002
Contact:
Postby nopnop2002 » Tue Apr 28, 2026 11:59 am
In ESP-IDF V6, the following options may help avoid deprecation-related errors.
This allowed us to temporarily circumvent the deprecation error related to the legacy TWAI driver.
However, it is not guaranteed that all errors can be avoided.
Users browsing this forum: Google [Bot], PetalBot and 1 guest
