I want to run the ESP-Vocat program (code) using Visual Studio Code and then flash it to the ESP-Vocat via Type-C.
I want to run the ESP-Vocat program (code) using Visual Studio Code and then flash it to the ESP-Vocat via Type-C. Since the ESP-Vocat program (code) is extensive, how should I do it? Which program (code) should I start running? Please tell me the detailed steps. Thank you.
Re: I want to run the ESP-Vocat program (code) using Visual Studio Code and then flash it to the ESP-Vocat via Type-C.
As the page for this devkit states, it uses the Brookesia projects for its examples, so I'd suggest you look there for more info.
Users browsing this forum: Applebot, Baidu [Spider], Bing [Bot], ChatGPT-User and 4 guests
