Reading DHT11 sensor in the loop with vTaskDelay behaves unexpectedly.
Eddous
Postby Eddous » Sat May 23, 2026 12:10 pm
Hello, I have a simple program that reads DHT11 sensor and logs the results.
When I add vTaskDelay(3000 / portTICK_PERIOD_MS) it seems that the code reads the DHT sensor only once and then skips it (and also it skips the first, but not the second ESP_LOGI()). Where may be the problem? Should I file bug report? What other information should I provide?
Code without vTaskDelay, behaves as I expect: (I assume that E (607) dht: Initialization error, problem in phase 'B' is caused by too fast reading)
#include <stdio.h>
#include "freertos/task.h"
#include "driver/gpio.h"
#include "esp_log.h"
#include "dht.h"
static const char *TAG = "MOLD-KILLER";
void app_main(void)
    ESP_LOGI(TAG, "Starting main()");
    float temperature = 0;
    float humidity = 0;
    esp_err_t result;
    while (1)
        result = dht_read_float_data(DHT_TYPE_DHT11, GPIO_NUM_5, &humidity, &temperature);
        ESP_LOGI(TAG, "After DHT read, result=%s, temp=%.1f, hum=%.1f", esp_err_to_name(result), temperature, humidity);
I (247) MOLD-KILLER: After DHT read, result=ESP_OK, temp=25.0, hum=69.0
I (607) MOLD-KILLER: After DHT read, result=ESP_ERR_TIMEOUT, temp=25.0, hum=69.0
E (1257) dht: Initialization error, problem in phase 'B'
I (1257) MOLD-KILLER: After DHT read, result=ESP_ERR_TIMEOUT, temp=25.0, hum=69.0
The same code, but with vTaskDelay, that looks like it skips reading the sensor and outputting values:
#include <stdio.h>
#include "dht.h"
void app_main(void)
    float humidity = 0;
    esp_err_t result;
    while (1)
        vTaskDelay(3000 / portTICK_PERIOD_MS);
        ESP_LOGI(TAG, "After delay");
I (237) main_task: Calling app_main()
I (237) MOLD-KILLER: Starting main()
I (1247) MOLD-KILLER: After delay
I (2267) MOLD-KILLER: After delay
I (3287) MOLD-KILLER: After delay
I (4307) MOLD-KILLER: After delay
I (5327) MOLD-KILLER: After delay
nopnop2002
Contact:
Re: Reading DHT11 sensor in the loop with vTaskDelay behaves unexpectedly.
Postby nopnop2002 » Mon May 25, 2026 12:27 am
The ESP32 works.
The ESP32C3 does not work.
Some SoCs are not supported.
Craige Hales
Postby Craige Hales » Tue May 26, 2026 3:26 pm
googling the error message produces a bunch of suggestions: wiring, noise, power, timing.
It seems odd that the delays in the log are about 1 second, not 3 seconds.
Inexplicable results might be a stack size issue too. Or incorrect parameters.
Craige
nopnop2002
Contact:
Postby nopnop2002 » Wed May 27, 2026 12:35 am
The critical section is having some kind of impact.
However, I don't know what caused it.
https://github.com/esp-idf-lib/dht/blob ... #L213-L216
Temporary solution:
#if 0
    PORT_ENTER_CRITICAL();
#endif
    esp_err_t result = dht_fetch_data(sensor_type, pin, data);
#if 0
    if (result == ESP_OK)
        PORT_EXIT_CRITICAL();
#endif
MicroController
Postby MicroController » Wed May 27, 2026 6:54 am
Temporary solution:
#if 0
#endif
#if 0
#endif
What about the PORT_EXIT_CRITICAL() at https://github.com/esp-idf-lib/dht/blob ... /dht.c#L99 ?
nopnop2002
Contact:
Postby nopnop2002 » Wed May 27, 2026 8:32 am
static portMUX_TYPE mux = portMUX_INITIALIZER_UNLOCKED;
#define PORT_ENTER_CRITICAL() portENTER_CRITICAL(&mux)
#define PORT_EXIT_CRITICAL() portEXIT_CRITICAL(&mux)
It's possible that the ESP32C3's portEXIT_CRITICAL function isn't working correctly.
Calling portEXIT_CRITICAL may not have actually exited the critical session.
However, I can't think of a way to verify that.
Eddous
Postby Eddous » Fri May 29, 2026 1:54 pm
This is my bad, I copied the wrong logs - logs are when I used 1second delay. However, the problem is the same when I use 1s delay and when I use 3s delay.
Eddous
Postby Eddous » Fri May 29, 2026 2:09 pm
Temporary solution:
#if 0
#endif
#if 0
#endif
May I ask where should I apply this fix? I tried to paste it into the dth.c file I have in managed components (full-clean and rebuild) and it did not fixed the issue.
Thank you for your time,
Eda
nopnop2002
Contact:
Postby nopnop2002 » Sat May 30, 2026 5:32 am
cd your_project
mv managed_components components
rm main/idf_component.yml
cd components/
cd esp-idf-lib__dht
edit dht.c
idf.py build
Users browsing this forum: ChatGPT-User, Qwantbot and 3 guests
