Failed to read NVS security cfg after migration 5.1->5.5
dizcza
Postby dizcza » Tue Jun 16, 2026 5:40 am
I have lots of
nvs: Failed to read NVS security cfg: [0x102] (ESP_ERR_INVALID_ARG)
after I migrated from v5.1 to v5.5 with security enabled (both full release and development).
 (622) quad_psram: This chip is ESP32-D0WD
I (622) esp_psram: Found 8MB PSRAM device
I (622) esp_psram: Speed: 40MHz
I (622) esp_psram: PSRAM initialized, cache is in low/high (2-core) mode.
W (628) esp_psram: Virtual address not enough for PSRAM, map as much as we can. 4MB is mapped
I (636) cpu_start: Multicore app
I (1518) esp_psram: SPI SRAM memory test OK
I (1532) cpu_start: GPIO 3 and 1 are used as console UART I/O pins
I (1532) cpu_start: Pro cpu start user code
I (1532) cpu_start: cpu freq: 160000000 Hz
I (1534) app_init: Application information:
I (1538) app_init: Project name:     esp32-sdpsensor
I (1543) app_init: App version:      bc6e086
I (1547) app_init: Compile time:     Jun 14 2026 09:34:04
I (1552) app_init: ELF file SHA256:  90d48a5d9f6a6ae7...
I (1557) app_init: ESP-IDF:          v5.5.4-1063-ge2face00fa1
I (1562) efuse_init: Min chip rev:     v3.0
I (1566) efuse_init: Max chip rev:     v3.99
I (1570) efuse_init: Chip rev:         v3.1
I (1575) heap_init: Initializing. RAM available for dynamic allocation:
I (1581) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1586) heap_init: At 3FFB9918 len 000266E8 (153 KiB): DRAM
I (1591) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1597) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1602) heap_init: At 4009AD70 len 00005290 (20 KiB): IRAM
I (1608) esp_psram: Adding pool of 4042K of PSRAM memory to heap allocator
W (1615) spi_flash: Detected winbond flash chip but using generic driver. For optimal functionality, enable `SPI_FLASH_SUPPORT_WINBOND_CHIP` in menuconfig
I (1628) spi_flash: detected chip: generic
I (1631) spi_flash: flash io: dio
I (1635) flash_encrypt: Flash encryption mode is RELEASE
W (1642) nvs: Failed to read NVS security cfg: [0x102] (ESP_ERR_INVALID_ARG)
I (1646) nvs: Generating NVS encr-keys...
E (1650) nvs: Failed to generate NVS encr-keys: [0x102] (ESP_ERR_INVALID_ARG)
Eventually, the app crashes with
W (00:09:07.979) nvs: Failed to read NVS security cfg: [0x102] (ESP_ERR_INVALID_ARG)
E (00:09:07.981) nvs: Failed to generate NVS encr-keys: [0x102] (ESP_ERR_INVALID_ARG)
W (00:09:07.984) wifi_creds: nvs_read_wifi_creds line 81: ESP_ERR_INVALID_ARG
W (4195) wifi:wifi osi_nvs_open fail ret=4353
W (00:09:07.995) wifi_init: Failed to unregister Rx callbacks
E (00:09:08.001) wifi_init: Failed to deinit Wi-Fi driver (0x3001)
E (00:09:08.006) wifi_init: Failed to deinit Wi-Fi (0x3001)
W (00:09:08.012) wifi_sta: wifi_sta_start line 198: ESP_ERR_NVS_NOT_INITIALIZED
E (00:09:08.019) esp_netif_lwip: esp_netif_new_api: Failed to configure netif with config=0x3ffbeb40 (config or if_key is NULL or duplicate key)
assert failed: esp_netif_create_default_wifi_sta wifi_default.c:422 (netif)
Backtrace: 0x4008d0ed:0x3ffbe9e0 0x4008d081:0x3ffbea00 0x40093c75:0x3ffbea20 0x4013d29f:0x3ffbeb40 0x400df5f3:0x3ffbeb70 0x400d871b:0x3ffbed70 0x401cb9be:0x3ffbee10 0x401cc1a2:0x3ffbee40
--- 0x4008d0ed: panic_abort at /home/dizcza/tools/esp-idf/components/esp_system/panic.c:477
--- 0x4008d081: esp_system_abort at /home/dizcza/tools/esp-idf/components/esp_system/port/esp_system_chip.c:87
--- 0x40093c75: __assert_func at /home/dizcza/tools/esp-idf/components/newlib/src/assert.c:81
--- 0x4013d29f: esp_netif_create_default_wifi_sta at /home/dizcza/tools/esp-idf/components/esp_wifi/src/wifi_default.c:422
--- 0x400df5f3: wifi_sta_start at /home/dizcza/Projects/Embedded/espressif-workspace/esp32-sdpsensor-secure/components_esp32/wifi_sta/wifi_sta.c:195
--- 0x400d871b: start_wifi_sta at /home/dizcza/Projects/Embedded/espressif-workspace/esp32-sdpsensor-secure/main/main.c:80
--- (inlined by) app_main at /home/dizcza/Projects/Embedded/espressif-workspace/esp32-sdpsensor-secure/main/main.c:108
--- 0x401cb9be: main_task at /home/dizcza/tools/esp-idf/components/freertos/app_startup.c:215
--- 0x401cc1a2: vPortTaskWrapper at /home/dizcza/tools/esp-idf/components/freertos/FreeRTOS-Kernel/portable/xtensa/port.c:143
And I think this is due to NVS config error I mentioned. Note that the same code works fine with no security enabled. I've read NVS Security migration guide 5.1->5.2 and haven't found any further steps I need to do for my setup. I already had nvs_keys in my partitions (I haven't changed the partition table):
# Name,   Type, SubType, Offset,   Size, Flags
# Note: if you have increased the bootloader size, make sure to update the offsets to avoid overlap
nvs,      data, nvs,     ,        0x4000,
nvs_key,  data, nvs_keys,,        0x1000, encrypted,
otadata,  data, ota,     ,        0x2000,
phy_init, data, phy,     ,        0x1000,
ota_0,    app,  ota_0,   ,        0x1e0000,
ota_1,    app,  ota_1,   ,        0x1e0000,
coredump, data, coredump,,        64K, encrypted
This renders to
# ESP-IDF Partition Table
nvs,data,nvs,0xd000,16K,
nvs_key,data,nvs_keys,0x11000,4K,encrypted
otadata,data,ota,0x12000,8K,
phy_init,data,phy,0x14000,4K,
ota_0,app,ota_0,0x20000,1920K,
ota_1,app,ota_1,0x200000,1920K,
coredump,data,coredump,0x3e0000,64K,encrypted
And according to the docs, it should work. Not sure if this is an issue or I'm still doing something wrong, hence decided to ask on the forum first. I have already bricked one security-enabled device (cannot start wifi due to this error and hence no OTA update) and have 6 more devices I need to migrate from 5.1 to 5.5 with security already enabled (3 devices release mode and 3 development).
My WiFi and NVS related code:
esp_err_t bsp_nvs_flash_init() {
    esp_err_t err = nvs_flash_init();
    if (err == ESP_ERR_NVS_NO_FREE_PAGES || err == ESP_ERR_NVS_NEW_VERSION_FOUND) {
        // NVS partition was truncated and needs to be erased
        // Retry nvs_flash_init
        nvs_flash_erase();
    return err;
bsp_nvs_flash_init();
ESP_ERROR_CHECK(esp_netif_init());
esp_event_loop_create_default();
wifi_sta->netif = esp_netif_create_default_wifi_sta();
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&cfg));
Screenshot from 2026-06-16 08-42-37.png (74.42 KiB) Viewed 59 times
How should I fix NVS and Wi-Fi-related issues on devices with security enabled when migrating from 5.1 to 5.5?
ESP_rrtandler
Re: Failed to read NVS security cfg after migration 5.1->5.5
Postby ESP_rrtandler » Mon Jun 22, 2026 11:49 am
Hi @dizcza ,
The IDF 5.2 has added one more indirection inside the nvs security. The concept is called nvs_security_provider.
The on-flash format is identical — read_security_cfg_flash_enc() in 5.2 ultimately calls the same nvs_flash_read_security_cfg() against the same nvs_keys partition. So if the 5.2 build is configured correctly (CONFIG_NVS_SEC_KEY_PROTECT_USING_FLASH_ENC=y, scheme registered), migration is seamless: the 5.1-written keys are read, the 5.1-encrypted NVS is decrypted, everything works.
The breakage is entirely in the new indirection layer:
In 5.1, key acquisition was unconditional and built into nvs_flash_init().
In 5.2, it depends on a separately-registered default scheme. When the project's sdkconfig is regenerated during the upgrade, the brand-new CONFIG_NVS_SEC_KEY_PROTECTION_SCHEME choice is resolved from Kconfig defaults. If CONFIG_NVS_SEC_KEY_PROTECT_USING_FLASH_ENC doesn't end up effectively set (its depends on SECURE_FLASH_ENC_ENABLED, or it lands on NONE), no scheme is registered → nvs_sec_default_scheme_cfg has null callbacks → nvs_flash_read_security_cfg_v2() returns 0x102 (ESP_ERR_INVALID_ARG) → the 5.2 "regenerate on any error" branch runs nvs_flash_generate_keys_v2(), which also returns 0x102 → nvs_flash_init() fails → Wi-Fi creds can't be read → the esp_netif_create_default_wifi_sta assert.
Please check the sdkconfig of your IDF 5.2 based upgrade and check presence and values of:
If these are not present, start menuconfig and navigate to "component config->NVS Security Provider" and set the Key protection scheme - to Using Flash Encryption. In order to see the settings, the flash encryption has to be enabled (this part is set in your project already)
dizcza
Postby dizcza » Mon Jun 22, 2026 5:21 pm
Hi @dizcza ,
Wow, thanks for the detailed route of where the error comes from and the steps I need to do. I didn't have the CONFIG_NVS_SEC_KEY_PROTECTION_SCHEME key in my menuconfig at all. I read the docs and added
REQUIRES nvs_sec_provider
After that, it's set to "Using Flash Encryption". And I guess the error should be resolved if I just reupload the OTA image with this flag enabled and call OTA update for my old v5.1 boards. I'll definitely try this once I have my boards with me.
Many thanks!
Users browsing this forum: Baidu [Spider], ChatGPT-User, PetalBot and 2 guests
