esp32 nimble gatt server official example not working
akashgaur0001
I am using the ble get started example from nimble named NimBLE_gatt_server(raw code) it connects with my using the app nrf connect but when i read write or subscribe at every 4 to 8 read or 4 to 8 write same for subscribe it gets automatically disconnected and if i again try to reconnect without manually resetting the control it do not connect.
- 01NimBLE_GATT_Server.zip
- example code
- (92.52 KiB) Downloaded 1 time
- logs when the code is running and it gets disconnected
- subscribe .png (98.19 KiB) Viewed 15 times
- read.png (115.35 KiB) Viewed 15 times
Re: esp32 nimble gatt server official example not working
Error code 520 implies Connection Timeout indicating link supervision timeout or syncronization timeout. Is this issue seen with only one device ? Can you switch the phone to some other device and check ?
What happens if you use nimble's bleprph/ blecent example, do they work ?
Users browsing this forum: Bytespider, Google [Bot], PerplexityBot and 2 guests
