如题,但是如果接看串口一连串口,他也能自动立马启动。
也就是说如果 非调试模式,上电后必须按复位键才会启动。但是调试模式只要串口一连他就立马会重新启动。是固件刷入的方式不对吗?还是硬件上需要做什么配置才可以。
ets Jul 29 2019 12:21:46
configsip: 0, SPIWP:0xee
mode:DIO, clock div:1
load:0x3fff0030,len:6604
ho 0 tail 12 room 4
load:0x40078000,len:16764
load:0x40080400,len:4348
entry 0x40080664
I (29) boot: ESP-IDF v5.5.3-dirty 2nd stage bootloader
I (29) boot: compile time Jul 16 2026 10:39:26
I (29) boot: Multicore bootloader
I (31) boot: chip revision: v3.1
I (34) qio_mode: Enabling default flash chip QIO
I (38) boot.esp32: SPI Speed : 80MHz
I (42) boot.esp32: SPI Mode : QIO
I (46) boot.esp32: SPI Flash Size : 8MB
I (49) boot: Enabling RNG early entropy source...
I (54) boot: Partition Table:
I (56) boot: ## Label Usage Type ST Offset Length
I (63) boot: 0 nvs WiFi data 01 02 00009000 00006000
I (69) boot: 1 otadata OTA data 01 00 0000f000 00002000
I (76) boot: 2 phy_init RF data 01 01 00011000 00001000
I (82) boot: 3 flash_tone Unknown data 01 82 00012000 00080000
I (89) boot: 4 ota_0 OTA app 00 10 000a0000 00200000
I (95) boot: 5 ota_1 OTA app 00 11 002a0000 00200000
I (102) boot: End of partition table
I (105) esp_image: segment 0: paddr=000a0020 vaddr=3f400020 size=52c78h (339064) map
I (199) esp_image: segment 1: paddr=000f2ca0 vaddr=3ffb0000 size=051e0h ( 20960) load
I (205) esp_image: segment 2: paddr=000f7e88 vaddr=40080000 size=08190h ( 33168) load
I (216) esp_image: segment 3: paddr=00100020 vaddr=400d0020 size=116e20h (1142304) map
I (507) esp_image: segment 4: paddr=00216e48 vaddr=40088190 size=11194h ( 70036) load
I (529) esp_image: segment 5: paddr=00227fe4 vaddr=50000000 size=00020h ( 32) load
I (542) boot: Loaded app from partition at offset 0xa0000
I (542) boot: Disabling RNG early entropy source...
I (552) quad_psram: This chip is ESP32-D0WD
I (552) esp_psram: Found 8MB PSRAM device
I (553) esp_psram: Speed: 80MHz
I (553) esp_psram: PSRAM initialized, cache is in low/high (2-core) mode.
W (559) esp_psram: Virtual address not enough for PSRAM, map as much as we can. 4MB is mapped
I (568) cpu_start: Multicore app
I (1084) esp_psram: SPI SRAM memory test OK
I (1093) cpu_start: GPIO 3 and 1 are used as console UART I/O pins
I (1093) cpu_start: Pro cpu start user code
I (1093) cpu_start: cpu freq: 240000000 Hz
I (1095) app_init: Application information:
I (1099) app_init: Project name: voip_app
I (1103) app_init: App version: 1
I (1107) app_init: Compile time: Jul 16 2026 10:38:12
I (1112) app_init: ELF file SHA256: 4aa5f5741...
I (1116) app_init: ESP-IDF: v5.5.3-dirty
I (1121) efuse_init: Min chip rev: v0.0
I (1125) efuse_init: Max chip rev: v3.99
I (1129) efuse_init: Chip rev: v3.1
I (1133) heap_init: Initializing. RAM available for dynamic allocation:
I (1139) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (1144) heap_init: At 3FFB7718 len 000288E8 (162 KiB): DRAM
I (1149) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
I (1155) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (1160) heap_init: At 40099324 len 00006CDC (27 KiB): IRAM
I (1166) esp_psram: Adding pool of 4080K of PSRAM memory to heap allocator
I (1173) spi_flash: detected chip: generic
I (1176) spi_flash: flash io: qio
I (1180) main_task: Started on CPU0
I (1183) esp_psram: Reserving pool of 18K of internal memory for DMA/internal allocations
I
ESP32-LyraT-Mini v1.2 通电后必须按RST才会启动。如何实现通电即可自动启动。
feifei2026
Jump to
- English Forum
- Explore
- News
- General Discussion
- FAQ
- Documentation
- Documentation
- Sample Code
- Discussion Forum
- ESP32-S31
- Hardware
- ESP-IDF
- ESP-BOX
- ESP-ADF
- ESP-MDF
- ESP-WHO
- ESP-SkaiNet
- ESP32 Arduino
- IDEs for ESP-IDF
- ESP-AT
- ESP IoT Solution
- ESP RainMaker
- Rust
- ESP8266
- Report Bugs
- Showcase
- Chinese Forum 中文社区
- 活动区
- 乐鑫活动专区
- 讨论区
- ESP32-S31 中文讨论版
- 喵伴 中文讨论版
- ESP-IDF 中文讨论版
- 《ESP32-C3 物联网工程开发实战》书籍讨论版
- 中文文档讨论版
- ESP-AT 中文讨论版
- ESP-BOX 中文讨论版
- ESP IoT Solution 中文讨论版
- ESP-ADF 中文讨论版
- ESP Mesh 中文讨论版
- ESP Cloud 中文讨论版
- ESP-WHO 中文讨论版
- ESP-SkaiNet 中文讨论版
- ESP 生产支持讨论版
- 硬件问题讨论
- 项目展示
- All times are UTC
- Top
- Delete cookies
About Us
Information
