Hi, I'm running the install script in esp idf. The script failes when installing python packages in idf created venv because it uses the system-wide msys2 python, which idf doesn't support.
I've installed a Windows CPython in uv. It requires its own venv to be activated. Is it possible to use the venv created by uv when running the esp idf install script? Thanks very much! Platform is Windows 11 x86-64
How to use already existing python venv when running install script in esp idf?
