"strptime" don't get compiled
Gfast2
Postby Gfast2 » Tue Nov 14, 2017 4:12 pm
Hi ESP-IDF,
today I have another issue, my toolchian can't figure out what is strptime. I've did some research on this. Some one said, it is not a standard C function, but a POSIX standard function. And my elcipse did successful found this function in <time.h>. But ESP-IDF still won't compile.
Any tipp for me?
#include <stdio.h>
#include <time.h>
#include "freertos/task.h"
void app_main()
    printf("Hello world!\n");
    struct tm tm;
    strptime("2017-11-11T11:11:11ZZ", "%y-%m-%dT%H:%M:%SZZ", &tm);
Error Log:
/home/gfast2/esp/esp-idf/examples/get-started/hello_world/build/main/libmain.a(hello_world_main.o):(.literal.app_main+0xc): undefined reference to `strptime'
/home/gfast2/esp/esp-idf/examples/get-started/hello_world/build/main/libmain.a(hello_world_main.o): In function `app_main':
/home/gfast2/esp/esp-idf/examples/get-started/hello_world/main/./hello_world_main.c:11: undefined reference to `strptime'
collect2: error: ld returned 1 exit status
/home/gfast2/esp/esp-idf/make/project.mk:372: recipe for target '/home/gfast2/esp/esp-idf/examples/get-started/hello_world/build/hello-world.elf' failed
make: *** [/home/gfast2/esp/esp-idf/examples/get-started/hello_world/build/hello-world.elf] Error 1
ESP_Angus
Re: "strptime" don't get compiled
Postby ESP_Angus » Wed Nov 15, 2017 6:31 am
Hi Gfast2,
Thanks for reporting this. This is a bug in IDF. The file is compiling correctly but linking is failing because strptime() is missing from the libc library. We are working on a fix.
Angus
Gfast2
Postby Gfast2 » Wed Nov 15, 2017 8:58 am
Thanks Angus,
As the work around, I use "sscanf()" which works on ESP-IDF right now, for someone who has the same problem right now. :)
cheers
Gfast2
ESP_Angus
Postby ESP_Angus » Thu Nov 16, 2017 10:38 pm
Glad you found a workaround. On the current IDF master branch (as of 7e8c2a9), strptime() will link correctly.
Users browsing this forum: No registered users and 162 guests
