Undefined Reference to "uxTaskGetSystemState" Upon Any Attempt to Use.
Fuzzyzilla
Postby Fuzzyzilla » Mon Nov 20, 2017 9:01 pm
Hello!
I have just started freeRTOS and I wanted to do some debugging of my tasks. I wrote a function to display all task states using "uxTaskGetSystemState()" but any attempt to use this function results in the following error:
C:\Users\...\AppData\Local\Temp\arduino_modified_sketch_317958/sketch_nov20a.ino:3: undefined reference to `uxTaskGetSystemState'
This happens on all computers I've tried it on. All other freeRTOS functions I've tried work fine, just not this one.
What can I do to fix this?
Thanks!
chegewara
Re: Undefined Reference to "uxTaskGetSystemState" Upon Any Attempt to Use.
Postby chegewara » Mon Nov 20, 2017 10:58 pm
This function requires configUSE_TRACE_FACILITY=1. You have to check this option in menuconfig:
menuconfig->Component config->FreeRTOS->Enable FreeRTOS trace facility
kolban
Postby kolban » Mon Nov 20, 2017 10:59 pm
If we visit the Github for the ESP-IDF and do a search for uxTaskGetSystemState() we eventually find this source:
https://github.com/espressif/esp-idf/bl ... ks.c#L2287
If we look at the source, we see that it only gets compiled in if the configUSE_TRACE_FACILITY is set to 1.
We can set this in the "make menuconfig" within FreeRTOS > Enable FreeRTOS trace facility.
Switch this on and recompile. If that doesn't help, please post back and we'll try something else.
Fuzzyzilla
Postby Fuzzyzilla » Mon Nov 20, 2017 11:25 pm
Thank you both for your answers. Do I have to install ESPIDF to access these options?
Edit: I tried changing the config file manually, that didn't help.
(tried setting CONFIG_FREERTOS_USE_TRACE_FACILITY to 'y' , '1', and 'true' and then recompiling in arduino.)
chegewara
Postby chegewara » Tue Nov 21, 2017 12:36 am
Im not sure but maybe try to change this option in sdkconfig.h
It is in sdk/include/config folder
Or change this file and set default value to y
https://github.com/espressif/esp-idf/bl ... onfig#L288
Fuzzyzilla
Postby Fuzzyzilla » Tue Nov 21, 2017 12:55 am
Yeah, I've scanned through the different files changing them to 1, it still doesn't work...
kolban
Postby kolban » Tue Nov 21, 2017 3:38 am
Ahh just noticed that you are using Arduino. It may be that the ESP-IDF distributed with the Arduino version you are using pre-dates the latest ESP-IDF into which this option was recently added. You'd want to check the ESP-IDF commit history and find out what this option was added and then compare that against the ESP-IDF distributed by Arduino. If Arduino ESP-IDF distribution pre-dates that then this suggestion won't work as described and you would either have to find a new solution or wait for the Arduino ESP-IDF distibution to catch up.
NickJames
Postby NickJames » Sun May 26, 2019 9:24 am
I managed to make this work with the following steps:
[*]run git log in arduino-esp32 to find the latest tagged IDF (3.1 in my case)
[*]checkout that tag in esp-idf
[*]copy sdkconfig from arduino-esp32/tools/sdk/sdkconfig to esp-idf/examples/get-started/blink/sdkconfig
[*]run make menuconfig in esp-idf/examples/get-started/blink, turn on the options mentioned above
[*]make
[*]copy build/freertos/libfreertos.a to Arduino/hardware/expressif/esp32/tools/sdk/lib/
[*]copy build/esp32/libesp32.a to Arduino/hardware/expressif/esp32/tools/sdk/lib/
After doing these steps, I was able to compile this example: https://www.freertos.org/uxTaskGetSystemState.html
with the following changes
[*]use uxTaskGetNumberOfTasks() instead of uxCurrentNumberOfTasks()
[*]hack the task status data out of memory. I've still messed something up because sizeof(TaskStatus_t) evaluates to 36, but the actual struct size in memory was 40. I offset the pointers manually. Please do pardon my language.
Code: Untitled.cpp Select all
void print_shit(void)
char *str = (char *)malloc(sizeof(char) * 2000);
memset(str, 0, 2000);
char *pcWriteBuffer = str;
TaskStatus_t *pxTaskStatusArray;
volatile UBaseType_t uxArraySize, x;
unsigned long ulStatsAsPercentage;
uint32_t ulTotalRunTime;
/* Make sure the write buffer does not contain a string. */
*pcWriteBuffer = 0x00;
/* Take a snapshot of the number of tasks in case it changes while this
function is executing. */
uxArraySize = uxTaskGetNumberOfTasks();
/* Allocate a TaskStatus_t structure for each task. An array could be
allocated statically at compile time. */
Serial.printf("sizeof TaskStatus_t: %d\n", sizeof(TaskStatus_t));
pxTaskStatusArray = (TaskStatus_t*)pvPortMalloc( uxArraySize * sizeof(TaskStatus_t));
memset(pxTaskStatusArray, 0, uxArraySize * sizeof(TaskStatus_t));
if( pxTaskStatusArray != NULL )
/* Generate raw status information about each task. */
Serial.printf("Array size before: %d\n", uxArraySize);
uxArraySize = uxTaskGetSystemState( pxTaskStatusArray,
uxArraySize,
&ulTotalRunTime );
Serial.printf("Array size after: %d\n", uxArraySize);
Serial.printf("Total runtime: %d\n", ulTotalRunTime);
/* For percentage calculations. */
ulTotalRunTime /= 100UL;
/* Avoid divide by zero errors. */
if( ulTotalRunTime > 0 )
/* For each populated position in the pxTaskStatusArray array,
format the raw data as human readable ASCII data. */
Serial.printf(" name runtime pct core prio\n");
for( int x = 0; x < uxArraySize; x++ )
TaskStatus_t *fuckit;
void *tmp = &pxTaskStatusArray[x];
void *hmm = tmp + (4 * x);
fuckit = (TaskStatus_t*)hmm;
// Serial.printf("Name: %.5s, ulRunTimeCounter: %d\n", fuckit->pcTaskName , fuckit->ulRunTimeCounter);
/* What percentage of the total run time has the task used?
This will always be rounded down to the nearest integer.
ulTotalRunTimeDiv100 has already been divided by 100. */
ulStatsAsPercentage =
fuckit->ulRunTimeCounter / ulTotalRunTime;
if( ulStatsAsPercentage > 0UL )
sprintf( pcWriteBuffer, "%30s %10lu %10lu%% %5d %5d\n",
fuckit->pcTaskName,
fuckit->ulRunTimeCounter,
ulStatsAsPercentage,
*((int *)(&fuckit->usStackHighWaterMark)+1),
fuckit->uxBasePriority);
else
/* If the percentage is zero here then the task has
consumed less than 1% of the total run time. */
sprintf( pcWriteBuffer, "%30s %10lu %10s %5d %5d\n",
fuckit->pcTaskName,
"<1%",
*((uint32_t *)(&fuckit->usStackHighWaterMark)+1),
pcWriteBuffer += strlen( ( char * ) pcWriteBuffer );
// Serial.printf("len: %d, idx: %d\n", pcWriteBuffer - str, x);
Serial.print(str);
/* The array is no longer needed, free the memory it consumes. */
// vPortFree( pxTaskStatusArray );
// free(str);
Code: Untitled.txt Select all
		Name        runtime  	   pct	  core  prio
loopTask 8361337 89% 1 1
IDLE0 9270465 99% 0 0
IDLE1 14782 <1% 1 0
CAN_RX_25 218240 2% 1 24
100Hz_CAN_send_ 144393 1% 1 3
tiT 11428 <1% 0 18
10Hz_CAN_send_t 19815 <1% 1 1
LED blinker 2382 <1% 0 0
CAN_WD_BI 4471 <1% 1 10
1Hz_CAN_send_ta 75161 <1% 1 1
CAN_RX_24 195768 2% 1 24
Tmr Svc 36 <1% 0 1
ipc0 3502 <1% 0 24
network_event 18 <1% 1 19
eventTask 23 <1% 0 20
CAN_RX 27 <1% 2147483647 15
CAN_LORX 20 <1% 1 19
mdns 141 <1% 0 1
esptimer 4469 <1% 0 22
ACAN2517Handler 60268 <1% 2147483647 24
ACAN2517Handler 215147 2% 2147483647 24
ipc1 22592 <1% 1 24
This forum is fine, but BBcode is an awful impediment. Good Night.
boarchuz
Postby boarchuz » Sun May 26, 2019 2:16 pm
Looks familiar :lol:
I wonder if this is any help to tie up that loose end:
https://github.com/espressif/esp-idf/bl ... ask.h#L176
Possibly CONFIG_FREERTOS_VTASKLIST_INCLUDE_COREID is different between the relevant precompiled file and the sdkconfig that Arduino uses?
NickJames
Postby NickJames » Sat Jun 01, 2019 3:34 am
Thanks @boarchuz, adding `-DCONFIG_FREERTOS_VTASKLIST_INCLUDE_COREID` to the `build.extra_flags` in platform.txt was all I needed.
While this approach has provided some very useful information on tasks, it has also unfortunately broken part of the WiFi stack.
Users browsing this forum: ChatGPT-User, PerplexityBot and 1 guest
