ESP32 Thing (from SparkFun) questions
Feitan
Postby Feitan » Thu Nov 30, 2017 8:37 pm
Hi guys ! I'm a beginner in Arduino/microcontroller technologies.
I have some questions about the ESP32 Thing from SparkFun :
1) I want to link two sensors to the chip, however both of them are using SDA and SDL port, is it possible to use both sensors at the same time (soldering them) ?
2) Is is possible to retrieve the date/hour by connecting to a Wi-Fi network ?
Thanks for your help :)
Graphical Datasheet.pdf
(650.03 KiB) Downloaded 479 times
hakkig
Re: ESP32 Thing (from SparkFun) questions
Postby hakkig » Sat Dec 02, 2017 7:41 am
1) Yes, esp32 has two i2c ports, mappable programmatically.
2) Yes, search for "esp32 ntp example".
Feitan
Postby Feitan » Mon Dec 04, 2017 8:45 pm
Ok ! Thank you for your help
Users browsing this forum: PerplexityBot, Qwantbot, YisouSpider and 1 guest
