openocd & esp32 DevKitC on Linux
zamek42@gmail.com
Postby zamek42@gmail.com » Sat Dec 02, 2017 7:37 pm
Hi All,
I have an esp32 DevKitC, everything is working well except debugging. I use Debian Linux x64, and lsusb said:
Bus 004 Device 007: ID 10c4:ea60 Cygnal Integrated Products, Inc. CP210x UART Bridge / myAVR mySmartUSB light
It is not a FTDI chip, and I cannot set it on openocd. I've downloaded openocd source and I can compile it, but how can I set this chip?
There are no entry in the 99-openocd.rules file.
thx,
Zamek
Re: openocd & esp32 DevKitC on Linux
Postby Sprite » Sun Dec 03, 2017 10:47 am
Sorry, DevkitC does not have an on-board JTAG adapter chip; the ESP32-Wrover-Kit does, maybe you've confused these two. You can still get JTAG-debugging support, but you'd need to use an external JTAG adapter.
zamek42@gmail.com
Postby zamek42@gmail.com » Sun Dec 03, 2017 12:18 pm
Ok, thx.
I have an c232hm-ddhsl-0 cable. It has a
Bus 004 Device 006: ID 0403:6014 Future Technology Devices International, Ltd FT232H Single HS USB-UART/FIFO IC
chip.
Can I use it with openocd? And what is connection scheme of this, because it has 10 individual pins on it.
thx
Zamek
Postby Sprite » Sun Dec 03, 2017 6:47 pm
As far as I know, nope. You need an FT2232, your cable has an FT232.
meowsqueak
Postby meowsqueak » Tue Dec 05, 2017 3:59 am
Actually, I think the FT232H is OK - it has an MPSSE so is basically a one-channel version of the FT2232. The FT232R is not sufficient though.
I have a C232HM-EDHSL cable (which is the same as the -DDHSL but 5V not 3.3V on the VCC pin). This has the the FT232H and I'm able to JTAG debug and flash the ESP32 with it, using OpenOCD.
I use the ESP32 fork of OpenOCD with the following config:
interface ftdi
ftdi_vid_pid 0x0403 0x6014
ftdi_channel 0
reset_config none
adapter_khz 20000
transport select jtag
When running OpenOCD I use the "-f tcl/target/esp32.cfg" option as well as the config file above.
$ src/openocd -f ../c232hm-edhsl-0.cfg -f tcl/target/esp32.cfg
Open On-Chip Debugger 0.10.0-dev-gcc5b0f7a (2017-09-04-14:45)
Licensed under GNU GPL v2
For bug reports, read
none separate
adapter speed: 1000 kHz
jtag
force hard breakpoints
Info : clock speed 1000 kHz
Then debug with:
$ xtensa-esp32-elf-gdb -ex 'target remote localhost:3333' ./build/<project>.elf
The Eclipse integration tends to work better than command-line GDB I find.
To program the ESP32 flash, I use:
$ src/openocd -s share/openocd/script \
              -f ../c232hm-edhsl-0.cfg \
              -f tcl/target/esp32.cfg \
              -c "program_esp32 <path/to/project/file.bin 0x10000 verify exit"
zamek42@gmail.com
Postby zamek42@gmail.com » Fri Dec 08, 2017 7:03 am
thx it seems good, I'll try it.
Users browsing this forum: Qwantbot, Semrush [Bot] and 4 guests
