use ESP32 as wifi AP/Ethernet switch ?
xaoyao
Postby xaoyao » Thu Nov 03, 2016 6:22 am
Hi All,
ESP32 has both wifi AP function and Ethernet interface.
Does anyone has a ESP32 solution for wifi AP device, with Ethernet interface to plug in a RJ45 port?
It act like a layer two switch, which transparent deliver between wifi/Ethernet, and convert 802.3 to 802.11 frame.
Note, it not has routing function, just layer two switch!
Best Regards.
Re: use ESP32 as wifi AP/Ethernet switch ?
Postby Sprite » Thu Nov 03, 2016 6:44 am
Right now probably not, as we're still writing both the documentation as well as the drivers about the Ethernet interface.
xaoyao
Postby xaoyao » Thu Nov 03, 2016 9:30 am
Thanks for reply.
So could you please give us the detail schedule about Ethernet driver and Wifi AP switch?
igrr
Postby igrr » Thu Nov 03, 2016 1:56 pm
Ethernet driver will be part of ESP-IDF 1.0 release. Please refer to this post: http://esp32.com/viewtopic.php?f=10&p=1779#p1708
As for packet switching, you will probably have to implement this by enabling routing between interfaces in LwIP.
xaoyao
Postby xaoyao » Fri Nov 04, 2016 6:26 am
Thank you for schedule.
"As for packet switching, you will probably have to implement this by enabling routing between interfaces in LwIP."
I think we may not need involve in LwIP.
We just need transparent transport the 802.11 frame from wifi port to 802.3 frame of ethernet port.
WiFive
Postby WiFive » Fri Nov 04, 2016 9:34 am
Well you still have to do L2 frame translation. Why do you want to use an IOT chipset to do this instead of an AP/router chipset?
xaoyao
Postby xaoyao » Fri Nov 04, 2016 9:38 am
because the cost. Wifi router chipset is too expensive.
WiFive
Postby WiFive » Fri Nov 04, 2016 10:27 am
Mt7688an is pretty cheap.
xaoyao
Postby xaoyao » Tue Nov 08, 2016 5:37 am
Thank you for your information.
Actually we didn't need router function, we just want extend wifi signal from ethernet port.
Is there any other more simply solution?
lnunez
Postby lnunez » Thu Aug 30, 2018 8:19 pm
Hi ESP_igrr
How can I enable routing between interfaces?
thanks
Users browsing this forum: Bytespider, Google [Bot], PerplexityBot and 1 guest
