Stack overflow & heap monitoring
dejan.ns
Postby dejan.ns » Fri Dec 22, 2017 12:45 pm
I know there is uxTaskGetStackHighWaterMark FreeRTOS function which can be used to get the minimum size of unused task stack, but I wonder if there is a ESP-IDF way of achieving this.
Also I would like to know what is the best method for watching the free heap size.
Re: Stack overflow & heap monitoring
Postby Sprite » Fri Dec 22, 2017 2:17 pm
Esp-idf uses FreeRTOS as its RTOS, so you can happily use uxTaskGetStackHighWaterMark. For the free heap size, you can use heap_caps_get_free_size(MALLOC_CAP_DEFAULT|MALLOC_CAP_8BIT). (Or use any other cap if you want to know stuff about the more specialized heap regions.)
Users browsing this forum: Amazon [Bot] and 2 guests
