Hard reset flash read err, 1000; Falling back to built-in command interpreter.
hakkig
Postby hakkig » Fri Dec 01, 2017 10:39 am
Hi Folks,
I get this "flash read err, 1000; Falling back ...." error in all the programs I tested so far.
This only happens when I hard reset the esp32 module or after wakeup from deep sleep.
After the error there is a another reset and everything seems to work normally.
This error is not issued after the reset after flash.
I checked similar threads, but could not find a definitive answer.
Bootloader is at 0x1000 and encryption is not enabled.
Any ideas? Should I ignore it?
Thanks in advance
------------------------- Manual reset
OK
>ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0xee
------------------------- Deep sleep reset
rst:0x5 (DEEPSLEEP_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
OK
rst:0x7 (TG0WDT_SYS_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
iot-bits.com
Contact:
Re: Hard reset flash read err, 1000; Falling back to built-in command interpreter.
Postby iot-bits.com » Tue Dec 05, 2017 7:12 am
I had this when I had set the crystal frequency incorrectly, and the flash clock speed was too high for the SPI flash chip. I'd suggest trying to use a slow speed flash SPI bus in DIO mode.
- Pratik
:geek: Just another hobbyist and consultant
hakkig
Postby hakkig » Thu Dec 07, 2017 3:56 pm
I tried both 26 and 20 MHz but did not help, thanks anyway.
Friends question is still pending.
Cheers
Chobby Race
Postby Chobby Race » Thu Dec 14, 2017 8:21 pm
I'm having the same exact issue. I'm using a button reset for deep sleep mode, and if pressed for a short second the device will get the 0x1000 flash error, but if I hold down the button it will first get the 0x1000 error but then properly wake from deep sleep mode after resetting . Hopefully this helps.
hakkig
Postby hakkig » Fri Dec 15, 2017 2:54 pm
As a matter of fact my situation is the same. My question is can we ignore the error message.
Chobby Race
Postby Chobby Race » Fri Dec 22, 2017 10:11 pm
It depends on what you want you are trying to do. When you get the 0x1000 Flash error, the chip will reset, so you lose any data you were trying to store. If this isn't an issue, then yeah you can ignore it.
hakkig
Postby hakkig » Sun Dec 24, 2017 7:25 pm
Thanks for the comment, cheers
Angus
Postby Angus » Tue Dec 26, 2017 11:43 pm
Some flash chips can take longer than expected to power on, so the first read (after the bootloader starts) sees invalid flash. This problem may be more prominent on some hardware board designs (power decoupling, etc).
There is a config option in ESP-IDF to avoid this problem when waking from deep sleep, by adding a small delay before normal booting resumes. By default on recent IDF this is set to 2ms, which was long enough for all the flash chips we tested, but you may want to try setting it higher:
http://esp-idf.readthedocs.io/en/latest ... keup-delay
Angus
hakkig
Postby hakkig » Wed Dec 27, 2017 11:42 am
Hi, thanks
I tested with 3000, 5000 and then 500 uS but the result is the same.
Maybe my board is faulty, I will order and test with a new one.
Cheers
Users browsing this forum: PetalBot and 0 guests
