Need help for HTTP Client Porting
Ritesh
Contact:
Postby Ritesh » Thu Jan 04, 2018 7:27 pm
We had started to look nghttpd2 component and tested http server with all GET, POST, PUT, DELETE requests which are working fine without any issue.
Now, we had requirement to make it same for HTTP Client.
So, Does anyone has any examples or links for that?
In short, we need example source or application for HTTP Client which should be running into ESP32 and can get data and other respective services from server.
Regards,
Ritesh Prajapati
WiFive
Re: Need help for HTTP Client Porting
Postby WiFive » Fri Jan 05, 2018 1:42 am
https://github.com/loboris/ESP32_curl_example
Can you publish your nghttp2 server component?
Ritesh
Contact:
Postby Ritesh » Fri Jan 05, 2018 5:17 pm
Means, do you need nghttp2 component which we are using?
Or Application code with parser which we are using?
Regards,
Ritesh Prajapati
WiFive
Postby WiFive » Sat Jan 06, 2018 1:41 am
Just wondering if you built server based on nghttp2 and package it as reusable component
Ritesh
Contact:
Postby Ritesh » Sat Jan 06, 2018 5:08 am
Yes. We already used nghttpd2 as server and able to serve HTTP GET/POST/PUT/DELETE using parser.
Now, we need to implement client instead of server for that.
Please send me some reference links or informations for that if you had any
Regards,
Ritesh Prajapati
WiFive
Postby WiFive » Sat Jan 06, 2018 5:13 am
You should publish your server on GitHub as a idf component
Here is curl client example from your friend loboris https://github.com/loboris/ESP32_curl_example
loboris
Postby loboris » Sat Jan 06, 2018 9:03 am
There is also much simpler esp-request library.
Searching the GitHub can always give you some useful information.
cmorgan
Postby cmorgan » Sat Jan 06, 2018 7:02 pm
@Ritesh, would you mind providing the output of your 'make size-components'? I'm interested in the overhead in terms of size of a nghttpd server to compare against the httpd server I'm more familiar with, libesphttpd.
Ritesh
Contact:
Postby Ritesh » Sun Jan 07, 2018 5:03 pm
Ok. Will send details w.r.t. component size tomorrow morning
Regards,
Ritesh Prajapati
Ritesh
Contact:
Postby Ritesh » Sun Jan 07, 2018 5:04 pm
Thanks Loboris,
Will check it and get back to you if any query regarding that.
Regards,
Ritesh Prajapati
Users browsing this forum: Applebot, Baidu [Spider], Semrush [Bot] and 2 guests
