Hello I try to setup a web server
Something like this works
client.println(HTML_Header[0]);
client.println(HTML_Header[1]);
client.println(HTML_Header[2]);
client.println(HTML_Header[3]);
client.println(HTML_Header[4]);
In a loop like this it's causing a reboot of the ESP32
for(i=0; i<5; i++)
client.println(HTML_Header);
To do this Serial.println(HTML_Header);
is working
I had the same Problem with the ESP8266
How can I use a String Array in the
Web Server Content with string array
Re: Web Server Content with string array
Hi solved the Problem with using sts:string Class
and every string has less then 30 chars like
std::string HTML_Header[] = { "<!doctype html>",
"<html>",
"<head>",
"<title>Temperature and",
" Humititdy Server</title>",
"<meta charset= \"UTF-8\">"
I don't know if that is working witch char arrays but i think it should
"<html>",
"<head>",
Users browsing this forum: ChatGPT-User, meta-externalagent and 2 guests
