Using Flash Encryption
Widgetman
Postby Widgetman » Tue Feb 13, 2018 10:57 pm
All,
Is there a good example on how to use the flash encryption scheme for applications. I would like to develop an app using this part and maintain encrypting the image outside of the part so that it is only decrypted inside and run. I would need to update it OTA if possible using wifi. Any thoughts or suggestions would be appreciated.
Re: Using Flash Encryption
Postby rudi ;-) » Wed Feb 14, 2018 9:13 am
All,
.or suggestions would be appreciated.
post this not in the NEWS
post this example in Discussion Forum
thanks
Postby Sprite » Wed Feb 14, 2018 10:29 am
Moved News -> General Chat
Angus
Postby Angus » Thu Feb 15, 2018 12:08 am
All,
Hi Widgetman,
Did you see the section on flash encryption in the documentation?
http://esp-idf.readthedocs.io/en/latest ... ption.html
This explains how to have your application encrypted in the ESP32 flash. OTA updating is supported when flash encryption is in use.
Angus
