How to read gpio configuration?
OutOfLine
Postby OutOfLine » Sat Feb 24, 2018 2:00 pm
I want to my program to read state of gpio pins.
On old Arduino hardware i did things like
// ATTENTION:  example code is for old Arduino boards, *not* ESP
  // input or output?
  reg = portModeRegister(port);
  if (*reg & mask) {		// digital OUTPUTS
    // high or low?
    reg = portOutputRegister(port);
    if (*reg & mask) {		    // HIGH
    } else {			    // LOW
  } else {			// digital INPUTS
    // pullup, tristate
    // similar code ...
How can I get similar informations on an ESP32?
Champ76
Re: How to read gpio configuration?
Postby Champ76 » Mon Feb 26, 2018 2:41 pm
If you are using Arduino core for ESP32, than use digitalRead(pin); which will return value 0 or 1.
You need to pass one parameter which is GPIO pin number. For example,
#include <Arduino.h>
#define MyPin 15
#define LED_BUILTIN 2
void setup(void) {
  Serial.begin(115200);
  pinMode(MyPin , INPUT);
  pinMode(LED_BUILTIN, OUTPUT);
void loop(void) {
  int pinState = 0;
  digitalWrite(LED_BUILTIN, pinState);
  delay(1000);
  pinState = digitalRead(MyPin);
  Serial.print("Pin State= ");
  Serial.println(pinState);
  digitalWrite(LED_BUILTIN, ! pinState);
  delay(2000);
By default pin value set to 0. In above example LED connected to pin 2 will OFF for 1 second and On for 2 second. This will repeat continuously.
OutOfLine
Postby OutOfLine » Tue Feb 27, 2018 9:37 am
thank @Champ76 for replying
but this is not what i need
i want to read *configuration* of a pin
like is the pin an input, output, pullup, and more
main use is debugging
robert
Users browsing this forum: Bing [Bot] and 3 guests
