new features?
xatax79
new features?
Postby xatax79 » Sun Nov 20, 2016 1:17 pm
Maybe can be some stupid question, but everybody talks about IoT, long battery life and higher coverage.
I have some question about:
- long range LPWAN for IoT applications (more than 1km range similar to LoRa or Sigfox) ?
- hidden SSID for the Wi-Fi network ?
Regards, Xatax
kolban
Re: new features?
Postby kolban » Sun Nov 20, 2016 4:48 pm
Re: hidden ssid for WiFi.
When the ESP32 offers itself up as a WiFi access point using the api "esp_wifi_set_config" its parameter is an instance of a "wifi_config_t". This has a flag called "ssid_hidden" and if set to true, the ESP32 will not broadcast its SSID.
luartos
Re: new features?
Postby luartos » Tue Nov 29, 2016 11:55 am
Hi xatax79,
Lua RTOS is available on github for ESP32:
https://github.com/whitecatboard/Lua-RTOS-ESP32
Lua RTOS has support for LoRa WAN. All is programmed in Lua in an easy way, for example for send a LoRa frame you only need to write this:
lora.setup(lora.BAND868)
lora.setAppEui("70XXX57ED0000XX0")
lora.setAppKey("8CXXXX5A80XXXX0FXX18XXBCXX41XXXX")
lora.setDevEui("XXB3XX7E000XX000")
lora.setDr(5)
lora.setAdr(false)
lora.join()
lora.tx(false, 1, pack.pack(25.2))
Best regards,
Lua RTOS team
Users browsing this forum: Amazon [Bot], ChatGPT-User and 7 guests
