GPIO internal pull-up and pull-down resistance value
sakurasaku
Postby sakurasaku » Fri Mar 23, 2018 1:00 am
What is the resistance value of the internal pull-up and pull-down of GPIO of ESP-WROOM-32?
please tell me.
Re: Internal resistance value
Postby Sprite » Fri Mar 23, 2018 1:23 am
It's not a really precise value (because that is hard to do with resistors in silicon) but you can assume it's something between 10K and 100K. Internally, we use 50K as a go-to value, I think.
sakurasaku
Postby sakurasaku » Fri Mar 23, 2018 1:37 am
Thank you very much. It was very helpful.
aanscharius
Re: GPIO internal pull-up and pull-down resistance value
Postby aanscharius » Tue Dec 13, 2022 3:21 pm
10K is waaayyy to low, if you have several pullup's downs, the drain from 3.3 or GND to all input becomes to high and the board will reset.
I use 1M and that works perfectly fine, even higher could be ok, the board is very sensitive!
regards
Johan
Postby Sprite » Thu Dec 15, 2022 1:23 am
...too low for what? Your comment doesn't really make sense in the context of this topic?
