UART Send Raw Bytes
klteng
UART Send Raw Bytes
Postby klteng » Sun Mar 25, 2018 4:54 am
The SDK UART API seems to send character only. How do I send a RAW byte? For example, I want to send data 0xAA.
kolban
Re: UART Send Raw Bytes
Postby kolban » Sun Mar 25, 2018 4:58 am
Might the uart_write_bytes API do the trick?
klteng
Postby klteng » Sun Mar 25, 2018 6:35 am
Hi Kolban,
How do you send the raw bytes? Do you have example code?
WiFive
Postby WiFive » Sun Mar 25, 2018 7:01 am
klteng
Postby klteng » Sun Mar 25, 2018 8:22 am
I have the following code:
int sendData(const char* logName, const char* data)
const int len = strlen(data);
const int txBytes = uart_write_bytes(UART_NUM_2, data, len);
ESP_LOGI(logName, "Wrote %d bytes", txBytes);
return txBytes;
static void tx_task()
static const char *TX_TASK_TAG = "TX_TASK";
while (1) {
sendData(TX_TASK_TAG, 0xAA);
vTaskDelay(2000 / portTICK_PERIOD_MS);
How do I declare the 0xAA as a byte? Currently the code expecting a string.
kolban
Postby kolban » Sun Mar 25, 2018 4:33 pm
Howdy my friend
how about
char data[] = { 0xAA };
sendData(data, sizeof(data));
In this case, pass the size of your data buffer in as a parameter.
klteng
Postby klteng » Mon Mar 26, 2018 12:40 am
Thank you very much. It works now!
Users browsing this forum: Bing [Bot] and 4 guests
