Need help to get default state of unused IO pads for ESP32 modules
Ritesh
Contact:
Postby Ritesh » Fri Apr 27, 2018 7:34 pm
Hi Espressif Systems Developer,
We have started to use ESP32 SoC as well as ESP32 based modules into different product which are running successfully.
Now, I have one question like what is the default state of unused GPIO or IO pads into module itself?
Let's take one example like there is one IO3 which I haven't used into my product then what will be the default state means HIGH or LOW and input or output direction.
So, I just want to get I formation regard that so that I need to configure it from software side if state is tristate or not fixed
Regards,
Ritesh Prajapati
WiFive
Re: Need help to get default state of unused IO pads for ESP32 modules
Postby WiFive » Sat Apr 28, 2018 1:12 am
Look at datasheet appendix A you can see that io3 has input mode with weak pull-up and default function is u0rxd
Ritesh
Contact:
Postby Ritesh » Sat Apr 28, 2018 6:36 pm
Thanks for Reply.
I will check and will let you know if any query regarding that.
Regards,
Ritesh Prajapati
