Sample for collecting data from SPI device
peterlspot
Postby peterlspot » Wed May 16, 2018 10:15 am
Does the SPI master driver support to get data from a slave device via SPI?
Assuming that SPI slave device can flag an interrupt line when there is data and then the MCU will be noticed via ISR and then a reader task will start reading the SPI data out using transactions. There are also some provision of the slave device (e.g. setup sampling rate) before enable the slave device.
Users browsing this forum: Semrush [Bot] and 1 guest
