Why IO2 of VSPI in QSPI mode is always read as 0 in Receiving phase?
huykhacnguyen
Postby huykhacnguyen » Sun May 20, 2018 4:02 am
Hi all,
I try to use VSPI in QSPI mode to increase communication speed.
ESP32 can write out register address, but when it reads back register data, IO2 bit is always read as 0 although it is 1 in a probed waveform.
Here is my code to configure VSPI in QSPI mode:
spi_device_handle_t spi;
spi_bus_config_t buscfg={
.miso_io_num = GPIO_NUM_19,
.mosi_io_num = GPIO_NUM_23,
.sclk_io_num = GPIO_NUM_18,
.quadwp_io_num = GPIO_NUM_22,
.quadhd_io_num = GPIO_NUM_21,
.max_transfer_sz= 16*320*2+8
spi_device_interface_config_t devcfg={
.clock_speed_hz = 1*1000*1000,
.mode = 0,
.spics_io_num = -1,
.queue_size = 7, //We want to be able to queue 7 transactions at a time
.flags= SPI_DEVICE_HALFDUPLEX,
//Initialize the SPI bus
ret = spi_bus_initialize(VSPI_SPI_HOST, &buscfg, 0);
if(ret != ESP_OK)
ESP_LOGE(TAG, "Failed to add QSPI device");
return false;
ret=spi_bus_add_device(VSPI_SPI_HOST, &devcfg, &SPIM);
if(ret != ESP_OK)
return false;
//Configure CS pin
gpio_config_t io_conf = {
.intr_type = GPIO_PIN_INTR_DISABLE,
.mode = GPIO_MODE_OUTPUT,
.pin_bit_mask = 1LL << GPIO_NUM_5,
ret = gpio_config(&io_conf);
if(ret != ESP_OK)
ESP_LOGE(TAG, "Failed to add CS pin");
return FALSE;
gpio_set_level(GPIO_NUM_5, 1);
//Test to read data of a register
gpio_set_level(GPIO_NUM_5, 0); //active CS
//send register addr
spi_transaction_t trans;
memset(&trans, 0, sizeof(trans));
trans.tx_buffer = reg_addr; //point to user buffer for Tx data
trans.rxlength = 0;
trans.length = 3*8; //3bytes of reg addr
trans.flags = 0;
trans.rx_buffer = NULL;
trans.flags |= SPI_TRANS_MODE_QIO;
spi_device_transmit(SPIM, &trans);
//read back reg data
trans.tx_buffer = NULL;
trans.length = 0;
trans.flags = 0;
trans.rx_buffer = &reg_data;
trans.rxlength = 4 * 8; //readback 4 bytes
The register addr is 0x3020C0 and the expected register data is 0xFFEE. However, ESP32 reads back as 0xBBAA ( all IO2 bits are read as 0). If IO2 bits are read as 1 then, it will return 0xFFEE which is expected.
I capture the waveform to check, IO2 bits are correctly output by slave device, but ESP32 always read as 0s.
I attach the waveform here. Note that in reading reg data phase, it reads 4 bytes but uses last 2 bytes (that requirement comes from the slave device.
Here is the print log from ESP32 showing that it reads back reg data as 0xBBAA
I (2183) GPU: Send 30,20,c0[3020c0]
I (2183) GPU: Rd16=aa,0,aa,bb
E (2183) FT8XX: Failed to check REG_PLAYBACK_FREQ[bbaa]
Should I miss anything? Is there any bugs in SPI driver in QSPI mode?
Please help.
Thanks,
Huy
Deouss
Re: Why IO2 of VSPI in QSPI mode is always read as 0 in Receiving phase?
Postby Deouss » Sun May 20, 2018 2:17 pm
Aren't you missing flags in transaction struct?
SPI_USE_TXDATA, SPI_USE_RXDATA
Also your receive code is wrong rx_data contains already allocated bytes from interrupt.
Try this
trans.rxlength = 3*8;
trans.flags |= SPI_TRANS_MODE_QIO | SPI_USE_TXDATA;
trans.length = 4*8;
trans.flags |= SPI_TRANS_MODE_QIO | SPI_USE_RXDATA;
huykhacnguyen
Postby huykhacnguyen » Mon May 21, 2018 8:54 am
I do not use SPI_USE_TXDATA, SPI_USE_RXDATA flags because I want to define a generic SPI Tx/Rx functions that can transfer arbitrary buffers from other modules. Besides, I check the SPI driver code and see that these flags is just to define whether SPI driver should use data from its internal 4-bytes buffer or from external larger buffer. So it may not relate to the issue here.
Thanks,
Huy
Last edited by huykhacnguyen on Mon May 21, 2018 9:00 am, edited 3 times in total.
huykhacnguyen
Postby huykhacnguyen » Mon May 21, 2018 8:57 am
That may not true. As I check, the SPI driver will record my Rx buffer so that it can write received data into in interrupt.
Anyway, I will give a try to double check my understanding.
Deouss
Postby Deouss » Mon May 21, 2018 11:25 am
Anyways - that's what I observed - there is already a memory data to be read in form of uint8_t rx_data[4]
I am not sure if it is DMA related
huykhacnguyen
Postby huykhacnguyen » Mon May 21, 2018 2:55 pm
Yes, you can read every 4bytes for each transaction if you specify the flag SPI_USE_RXDATA, if you want to read more data in one transaction, SPI_USE_RXDATA should not be used and you can input an user-defined RX buffer to store received data. That is what I read from the code.
Deouss
Postby Deouss » Mon May 21, 2018 3:40 pm
Then your settings are missing something. Probably larger buffers must be allocated certain way with certain malloc
huykhacnguyen
Postby huykhacnguyen » Tue May 22, 2018 1:59 am
Yes, I think something missing, but dont know what is it :(
Need help from community to solve this, not only for me, but also for others if they want to use QSPI mode because I see ESP32 does not have example code for SPI in QSPI mode. :|
huykhacnguyen
Postby huykhacnguyen » Tue May 22, 2018 4:00 am
Just found this ticket, maybe my issue is related to a bug in SPI driver
https://github.com/espressif/esp-idf/issues/1736
Users browsing this forum: ChatGPT-User, PerplexityBot and 1 guest
